Install Magnaflow or Factory Cat? - JeepForum.com
post #1 of 12 Old 06-21-2010, 05:21 PM Thread Starter
ZJ5point2GCL
I just bought a High Flow Cat from Magnaflow, but i also have a factory cat from a friend. The jeep didn't come with a cat, and when i put my headers and cat back on i didn't either (I know, I know, I regret it).
So my question is, install the Factory Cat? or the Magnaflow one?
Would i be killing my exhaust upgrades with a factory one? Or how much better is the Magnaflow one?
Thanks for your input
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #2 of 12 Old 06-21-2010, 07:28 PM
Ricochet88
magnaflow i have one it flows much better
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #3 of 12 Old 06-21-2010, 07:53 PM Thread Starter
ZJ5point2GCL
Did you notice any loss of low end tourqe?, like other people have mentioned in other threads.
post #4 of 12 Old 06-21-2010, 07:57 PM Thread Starter
ZJ5point2GCL
Also did you just clamp it on? Or weld it?
post #5 of 12 Old 06-21-2010, 09:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
No question....magnaflow.
ratmonkey is offline
post #6 of 12 Old 06-21-2010, 09:51 PM
xJoshxx
2012 WK
Magnaflow Weld it clamp Mufflers if you change em alot
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #7 of 12 Old 06-21-2010, 09:54 PM
Ricochet88
i have mine all welded and i didnt notice a lowend loss def alot of top end increase, i had a glasspack at first now that lost alot of lowend
Rick "woody"
my build thread
post #8 of 12 Old 06-21-2010, 10:03 PM Thread Starter
ZJ5point2GCL
How did you weld it to the mild steel, it being stainless?
post #9 of 12 Old 06-21-2010, 10:04 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
With nickel rod I'm sure.
post #10 of 12 Old 06-21-2010, 10:25 PM
Ricochet88
idk the muffler shop did it
Rick "woody"
my build thread
post #11 of 12 Old 06-21-2010, 10:43 PM Thread Starter
ZJ5point2GCL
o ok lol, too bad all the muffler shops here are either criminals or completely useless.
To day i argued with one shop that stainless steel exhaust tubing existed, and with another that wanted 500$ bucks for 10"s of tubing and to weld in a cat that i provided. And another that wouldn't even help me because i am "an 18 year old punk thats going to rip him off" how the heel can i rip him off if i am the one about to spend probably 100$ for 15 minutes of work.
I could easily do it my self if i had a hydraulic expander and a tig or a mig with gas.:
post #12 of 12 Old 06-28-2010, 01:36 PM Thread Starter
ZJ5point2GCL
well i got it installed a couple days ago, the only issue is i didn't allow enough room for heat expansion, where it goes over the axel then in front of the fuel tank, when its cold it has about 3/4'' clearance but when its hot, it gets so close it rattles over bumps, so ill have to fix that.
but other wise i am glad i went with the highflow, i cant even imagine how bad the factory cat would be, before it had plenty of power on the highway, now you have to get in the gas pretty hard to speed up or pass, and it drops a couple gears to 4500 rpm before it really starts moving.
catalytic converter , magnaflow
Factory Transfer Case Skid Install SkyjacktZJ ZJ Grand Cherokee Forum 4 01-01-2011 10:14 PM
help!!! factory fog light install on laredo MuddyNiner WJ Grand Cherokee Forum 7 05-03-2010 09:59 PM
Install factory trailer hitch info kevin1977 WK Grand Cherokee & XK Commander Forum 18 09-10-2009 07:19 AM
"factory" remote start - Install? mrfWKJeep WK Grand Cherokee & XK Commander Forum 0 10-15-2007 06:46 AM
to install a factory nav unit.... ItalianJeeper77 WK Grand Cherokee & XK Commander Forum 8 08-22-2007 09:51 PM
