Install Instructions (Rusty's 2" BB) - JeepForum.com
post #1 of 8 Old 04-15-2005, 02:05 PM Thread Starter
grovesj2
grovesj2's Avatar
Well, I just received Rusty's BB kit and the damn thing didnt have any instructions...so if you guys know of anywhere I can get some let me know. Thanks
- Jesse
grovesj2 is offline
post #2 of 8 Old 04-15-2005, 02:50 PM
10achik
I ate what?
10achik's Avatar
Kevin has a good write up...Here
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 8 Old 04-15-2005, 05:24 PM
cajunmudder
cajunmudder's Avatar
Make sure you take everything off that needs to come off (IE track bar, shocks, tie rod). Me and my friend wasted an hour trying to find a shortcut with no avail. But it is really easy
99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
cajunmudder is offline
post #4 of 8 Old 04-15-2005, 05:41 PM
10achik
I ate what?
10achik's Avatar
I didn't take any of that off for my WJ. I took out the sway bar and shock bolts, jacked up the other side took out the coil spring removed the rubber isolator and added the spacer, put the issolator back on, used the spring compressor to slightly compress the spring put it back in, took the compressors off and move to the next. I've seen where it was recommended to remove the track bar, but I'm here to tell you I didn't and it went smoothly (well except for that compressor malfunction that nearly took off my finger and put a hole in the wall. Other than that, it was pretty easy, took about 2.5 hours, with breaks
Ken
2006 Pontiac G6 GTP
10achik is offline
post #5 of 8 Old 04-15-2005, 06:45 PM
nosewitdot
is this basically the same if you're doing a suspension lift? cuz i am getting OME springs and shocks
nosewitdot is offline
post #6 of 8 Old 04-15-2005, 06:46 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you looked under the Faqs post you'll see the BB bold post at the bottom. The installation instructions are there.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 04-15-2005, 07:55 PM
MtnbikerWJ
MtnbikerWJ's Avatar
I am with IOchick on not needing to take the trackbar off. The only thing I did different was jack up the one side put the spring compressor on then let it down. Use the jack to compress the spring not the spring compressor. Spring compressor is there to just hold it together
04' WJ Laredo 4.0L 4x4
245/75-16 GY MTR's
Rusty's 2" BB
ARB Bull Bar with Piaa 520 drivings, no winch yet though
Kenwood Headunit, Kenwood Sirius Reciever, RF Punch p2002 Amp, RF Punch 10" Sub enclosure
Hypertech power programmer
K&N 77 series FIPK
Flowmaster 50 SUV
Magnaflow Cat
next gears and lsd's and OME coils
Colorado Jeep Club Member #14
White Jeep Club Member #114
MtnbikerWJ is offline
post #8 of 8 Old 04-15-2005, 08:13 PM
10achik
I ate what?
10achik's Avatar
I did that also, note my last sentance, that was the cause of the nearly lost finger and hole in the wall. I bought a cheap set from cummins tools and the spring compressor literally exploded when I lowered the jack, it stripped the threads and shot out from under there with a quickness. Now this was my fault for going cheap, I ended renting a good set from NAPA and just compressed the spring with it already out with my impact wrench (basically tightning it a little at a time on each time)
Although the other way suggested is probably a better way, I was just a little gun shy after the first mishap
Ken
2006 Pontiac G6 GTP
10achik is offline
5.2 water pump install instructions nickwygant ZJ Grand Cherokee Forum 3 05-09-2009 02:11 AM
Install cost for a 3" lift? (Rusty's) Ubergrob ZJ Grand Cherokee Forum 12 12-31-2008 08:54 AM
Rusty's Instructions JaredWJ ZJ Grand Cherokee Forum 2 11-11-2008 08:39 PM
ARB Bulbar install instructions drewman141 ZJ Grand Cherokee Forum 7 04-08-2006 08:19 PM
Rusty's Tow Hooks - Great Parts, Lousy Instructions Meerkat ZJ Grand Cherokee Forum 38 11-15-2005 10:25 PM
