Quantcast Inner axle seal/axle tube seal. - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Inner axle seal/axle tube seal.
BLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers3/8" Amsteel Blue Winchline Available in Blue, Green,
Old 03-09-2010, 10:22 PM   #1
MrJayDeeM
I have a leaky axle seal on my passenger side and I know it's from the inner seal where axle slide into. It happen after I installed new axles. I'm trying to find this seal any where and no body makes them anymore? I was wondering if Axle tube seal where it sits on the outside will work the same?
Something like this.
I still have the cv boot style axle though. If not, where can I find a replacement seal?
2000 Jeep Cherokee Sport
Quality Auto Paint & Body Inc
Roanoke, Va
MrJayDeeM is offline   Reply With Quote
Old 03-10-2010, 03:47 AM   #2
Technohead
Old school
Technohead's Avatar
I have those axle seals. Got them from 4wd hardware. Another company has copied the design.
BTW, these are intended to keep dirt & water from entering the axle tube not to keep oil inside the diff. If you have oil leaking out then you need to replace the oil seal.
Technohead is offline   Reply With Quote
Old 03-10-2010, 04:05 AM   #3
ChrisYJ - Italy
They are available from Alloy USA, i got some from 4wd.com too.
But i agree that those are intended as a dust-grime seal and not as an oil seal, do it right and replace the leaking seal before you grenade your diff!
(You are pulling the axles anyways to install the dust shields...)
ChrisYJ - Italy is offline   Reply With Quote
Old 03-10-2010, 10:04 AM   #4
gomes512
1994 ZJ
That and you'd probably have to fill it with 10 quarts of diff fluid...
It is hard to find them in stock in most parts stores as the demand is low. I know Napa has them but here are two links by just searching "D30 axle seal" on google.
Jeep Dana 30 Axle Shaft Seal JEE8121781 - 4Wheelers Supply
Omix-Ada: 16526.02 - Inner Axle Oil Seal, Dana 30
If it were me I'd go with the Spicer.
gomes512 is offline   Reply With Quote
Old 03-10-2010, 11:08 AM   #5
gatorayde
You have to pull the diff out to replace the inner seals. A bit more work than just the shafts (tie rod, diff cover, bearing caps, carrier, etc)
gatorayde is offline   Reply With Quote
Old 03-10-2010, 11:39 AM   #6
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Those seals won't work for you anyways...the CV joint is too big. Like everyone else said, you need to replace the inner seals. Replace both while you're in there - it is stupid to only do one (shops will do this).
ArloGuthroJeep is offline   Reply With Quote
Old 03-10-2010, 02:28 PM   #7
ChrisYJ - Italy
Sure it is, but what i meant it is that you'll get your hands dirty anyways, so better to just bite the bullet and do it all while you're at it
Old 03-10-2010, 06:48 PM   #8
MrJayDeeM
I didnt replace the seals when I pulled apart the front axle last night. Not too long ago either. I'm still looking for seals and I haven't tried Napa yet.
Roanoke, Va
Old 03-11-2010, 05:37 PM   #9
MrJayDeeM
I was having an arguement with my dad earlier about the seal. I asked him to go to napa as a favor to see if they have any seals while I was at work. He went and talked to this guy about the seal. My dad keeps thinking that its the outer seal where the cv boot would be and I tried to tell him that we don't have one at all period. He said the part service told him that there a new desgin to it and he bought it to bring home to show me. When I saw it, I told him I believe its the seal for the inner, he said no it's for the outside where the cv boot is.
Now, you guys tell me, here a picture of the seal. Who's right? Inner seal next to the differential or outside where the axle is?
Here's a picture.
Roanoke, Va
Old 03-11-2010, 07:21 PM   #10
MrJayDeeM
Father and son argument about seal.
Seal is for a front axle tube on dana 30. It leaks.
Here's a picture.
Roanoke, Va
Old 03-11-2010, 07:23 PM   #11
baxy
this is an inner seal
baxy is offline   Reply With Quote
Old 03-11-2010, 07:24 PM   #12
MudDuck99
Inner
10 char
[FONT="Arial Black"][SIZE="4"][B][COLOR="Teal"]Founder of the Steel Blue Jeep Group[/COLOR][/B][/SIZE][/FONT]
MudDuck99 is offline   Reply With Quote
Old 03-11-2010, 07:28 PM   #13
GraKee99
GraKee99's Avatar
Looks like the inner outer seal.
Brian
WJ, WK, CJ5
GraKee99 is online now   Reply With Quote
Old 03-11-2010, 07:32 PM   #14
spidermonkey
Thats an inner. I have one just like it. The other side is different for my disconnect housing. Don't even bother unless you change both, since you have to pull the whole axle apart anyway. Also make sure the shafts are clean where they contact the seals.
98ZJ, 4.0,242, 8.8 Detriot, hp30, 4.56's
My build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote
Old 03-11-2010, 07:34 PM   #15
MrJayDeeM
He bought me both side anyhow. So it's inner after all. Next to the carrier correct?
Roanoke, Va
Glock Forum
