BOSCH part number ending in 703. 4-hole injector found in some mid 90s chrysler cars. there is a huge thread discussing it on here. I did it and I highly reccomend it to everyone
I recently swapped the injectors in my 98 4 liter GC with the 703 injectors from the 96 Stratus. I have to say this was a cheap easy upgrade and the benefits I see so far are amazing. I had 3 leaky injectors so i has starting issues. The truck sounds like a totally different vehicle, its idle is amazing and the throttle response is also much better. I'm doing a test on the fuel economy difference now and will post the difference when my tank gets to empty. I heard I should see a 20 mile increase per tank so here's hoping. It has to be better since the gas is now being atomized so much better with the 4 hole injectors over the 1 hole ones the truck came with.
I believe you can get them from the 4.6 crown vics and mustangs as well. People choose this route because then you're able to get them all off of one car. If you go the Dodge Neon route, you have to use them from 2 separate cars since they are 4 cylinders. I haven't done it yet, but its on my list of soon-to-come mods.
Here is the part number to 1 of the bosch injectors. I think its the Dodge Neon one - 0280155703
Oh by the way, soy boricua. Naci en San Juan. Tengo un primo que vive en el campo y tiene un Cherokee turbo. Dejame saber si lo ves por ahi...Puerto Rico no es grande haha.
So do you know if the Ford 24lb injectors flow the same or near the same as the 703's? Just asking because it's easier to find a set of 8 in those than the 703's.
I honestly have no idea what the 703's are factory rated at, I just know that my flow test numbers (237.8cc/min @3Bar) were almost identical to Witchhunters' test numbers (238cc/min@3Bar). I haven't done any testing for the Ford units, but if you know their part numbers you could check if Witchhunter has already tested them.
I just looked they are the 703s. I haven't maxed them yet (exhaust, tune,minor port work, rocker arms) all small stuff. But soon ill be needing new injectors.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
