information display - JeepForum.com
post #1 of 4 Old 06-19-2003, 04:11 AM Thread Starter
PaulV
information display
I have a 1996 Grand Cherokee. The information display in the center console is displaying 2 errors. One error is for the rear brake lights. I have checked, and both are working, along with the turn signals and running lights. What should I look for?
Also, the display is saying the coolant sensor is bad. I am not having any overheating.
Where is the coolant sensor located? And how do I check it to see if it is bad?
Anything else I should look for?
Thanks,
Paul
PaulV is offline
post #2 of 4 Old 06-19-2003, 07:07 AM
ALS59LTD
ALS59LTD's Avatar
When I first got my jeep it said there was a problem with the brake lights, yet they all worked. I just replaced them all (backup, turn, brake, and highmount brake) and that solved the problem. I think as the bulbs get older the resistence changes, which is how it senses an out light. not sure about that coolant sensor....
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
post #3 of 4 Old 06-19-2003, 07:12 AM
jeepme79
Check the brake lights at the top of the window. I had the same problem when I bought mine.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
post #4 of 4 Old 06-19-2003, 10:28 AM
anthonyh75
I think the coolant sensor is in your overflow resivoir. It will only tell you if your coolant is low not the condition of it.
1998 5.9L Limited, 99 TL 1000s, 1995 Stingray 586zp
anthonyh75 is offline
Need Display Help!! pattydaddy ZJ Grand Cherokee Forum 7 09-11-2008 10:53 PM
Display pattydaddy ZJ Grand Cherokee Forum 0 09-09-2008 11:02 PM
No VIC display at all TripleRLtd ZJ Grand Cherokee Forum 11 07-08-2008 04:39 PM
RB1 Display TJTony ZJ Grand Cherokee Forum 3 01-10-2008 12:30 AM
Information display after stereo install? Phrozin ZJ Grand Cherokee Forum 3 03-26-2004 03:01 AM
