08-03-2005, 03:03 AM
#1
Information Center install '96 ZJ
Hey, I got an information center off of ebay and is supposed to bein working condition. My ZJ did not come with one from factory. I also got the rear lamp sensor and all the fluid sensors. I installed all of it along with the information center and nothing happend. All the harnesses were there and plugged right in. Am I missing something? Is this something that needs to be turned on at the dealer? --=Keith
08-03-2005, 03:12 PM
#2
^Bump Any one have any idea?
08-03-2005, 05:42 PM
#3
hmmm wish i could help but frankly i dont know what the heck youre talking about
BUMP
This guy needs help guys
4.0,30" BFG allterrrains,K&N FIPK, Screamin; Demon ignition coil, dist cap, and wires, ARB bull bar, blacked out grille,Ultrabrite headlights. Clear corners
[B]FOR SALE:[/B] [U]STOCK:[/U] distributor cap, rotor, and ignition coil. [U]STOCK[/U]: K&N air filter.
I'll sell these cheap parts for...you guessed it cheap. PM for anything you didnt feel you got here.
08-03-2005, 06:07 PM
#4
BUMP
he's talkin about the VIC i believe. thats the little computer display that some jeeps came with. other than that, i have no clue
08-03-2005, 08:23 PM
#5
Here are some schematics to help you check your set-up. The only other thing I can think of is that the Message Center, being strictly analog doesn't have a connection for the CCD bus, which the Visual Information Center requires.
HTH
Warren
Black 1996 5.2L ZJ Limited
08-03-2005, 08:24 PM
#6
Here're some more...
Warren
#7
And the last one...
Warren
08-04-2005, 04:41 PM
#8
Hey thanks for the schmatics... I'll check it out... I figure if it's prewired, all of it should light up right? I hope it's not a feature that needs to be turned on with the dealer cuz they didn't know what i was talking about =T Do you have the wire harness pin out break down for the BCM also? --=Keith
08-04-2005, 07:20 PM
#9
Originally Posted by keithqnguyen
<snip> Do you have the wire harness pin out break down for the BCM also? --=Keith
You don't ask for much, do you?
I'll see what I can come up with....
Warren
08-04-2005, 07:26 PM
#10
Former Mod
Jesus! This post makes me flashback to why I dropped my Physics Major after only 2 week of college!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
08-04-2005, 07:55 PM
#11
Phil!
UR2funny!
Here's the BCM stuff:
Warren
