Information center - JeepForum.com
post #1 of 12 Old 11-11-2013, 06:40 AM Thread Starter
metrik
1990 XJ Cherokee
Information center
M getting false errors on my information center on my 98 zj. It shows that te break lights aren't working but they are. Getting sick of hearing the beeping noise every so often. Anyone have a clue about this? Also shows a coolant sensor error
metrik is offline
post #2 of 12 Old 11-11-2013, 06:45 AM
kodenz
The VIC goes bad after 10-15 years, u can take it out and solder some of the connections to fix it, along with the dimmer switch if ur having flickering dash light problems.
The brake light alarm may be going off because there are several bulbs that burnout back there and the alarm won't go away till you fix them all. As for coolant sensor bad, that's probably just due to the Vic crapping out
sent from: somewhere
5.2L 1997 ZJ limited Up-Country+2in BB
kodenz is offline
post #3 of 12 Old 11-11-2013, 03:22 PM
rlcii77
What "kodenz" said... You can remove the VIC, take it apart and solder the connector pins on the board... Here's an excellent write-up... I did that a couple, few weeks ago on my VIC and my "Coolant Sensor Bad" message has yet to come back... The tail light message may be due to one of the third brake light bulbs, the middle bulb was my culprit, it's hard to notice unless you pull the assembly out and check...
'72 CJ5 Ren
'91 XJ, '96 XJ, '98 XJ
'94 ZJ, '96 Orvis ZJ
'98 Platinum 5.9, '98 Slate 5.9 (DD)
rlcii77 is offline
post #4 of 12 Old 11-11-2013, 03:27 PM
dnuccio
easiest solution:
1. remove VIC
2. install 2wd ZJ cubby box
3. smash VIC with hammer
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 12 Old 11-11-2013, 03:45 PM
zj97ltd
VCs and VICs get no love on here lol.
zj97ltd is offline
post #6 of 12 Old 11-11-2013, 04:00 PM
WJ4x4LIFE
I personally LOVE both of mine.
WJ4x4LIFE is offline
post #7 of 12 Old 11-11-2013, 05:53 PM
JasonStebbins
These VICS are worthless unless they are 100% functional which is almost never. It could indeed be bad soldering but check your third brake light bulbs, license plate bulbs and corner bulbs on the tail light.
Agree with using that space for storage/toggle switches.
Poop
JasonStebbins is offline
post #8 of 12 Old 11-11-2013, 06:17 PM
rlcii77
Not completely useless, it informs me when my kids only get their doors halfway shut... lol (sarcasm)
On mine, if I didn't look very closely, it would be easy to think the connector pins were ok, but, when looking at them through a magnifying glass, it was obvious, the cracks between the solder on the pins and board were very defined and noticeable...
Sent from Lee's Samsung Galaxy Note II using JeepForum
'72 CJ5 Ren
rlcii77 is offline
post #9 of 12 Old 11-11-2013, 10:21 PM
peyton
Mine was giving the same errors. Re-soldered the pins and the coolant sensor and 4wd switch errors had gone but I was still getting the brake light error. I checked the bulbs and the third brake light had the wrong type of bulbs in them. Replaced with the correct style and the vic has been quiet since.
98 xj classic/ 4.0
98 zj limited 5.2
peyton is offline
post #10 of 12 Old 11-12-2013, 03:49 AM
zj97ltd
The VIC is a great thing when it works. I'd rather it tell me I have a rear bulb out than a cop. Even little things like low washer fluid are good to know when you need them.
zj97ltd is offline
post #11 of 12 Old 11-12-2013, 04:08 AM
AVR2
I love my VIC too, but them I'm a sucker for gimmicky digital displays in older vehicles
AVR2 is offline
post #12 of 12 Old 11-12-2013, 04:30 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
All about your point of view, I had a cubby and that gaping hole always bothered me. I was constantly picking stuff off the floor that came out of it. So I installed a vic. Op may have a bad LOM possibility? Sockets get kinda crusty too in this age vehicle leading to intermittent operation. Best thing I like about a vic is it aggrevates me into changing the oil. That and the cop thing.
Originally Posted by HighLonesome
coralman is offline
