infinity gold headache...... - JeepForum.com
post #1 of 2 Old 09-09-2004, 11:38 AM Thread Starter
jandohnson
I have a 95 grand cherokee limited. For some reason, the front right speaker and tweeter arent getting any power. I switched the speakers with the ones on the left side and they worked fine so i know its not the speakers. I also threw in a new head unit and they still dont work. Also checked the connections to the amp, everything seems to be in place. Anyone have any suggestions??????
jandohnson is offline
post #2 of 2 Old 09-09-2004, 06:07 PM
Double E
Double E's Avatar
Sure....
1. Get a meter that can test for continuity.
2. Disconnect the problematic speaker's wires at the radio.
3. "Bridge" the + & - connection to the the speaker or wire them together temporarily.
3. Use the continuity test of the meter to show you what he problem is. (sounds like a disconnect somewhere).
4. If you get continuity, test the OHM readings too but compare it with the speaker wires on the other side (that are working). If it's a voltage leak or frayed wire, I would think there would be a large difference in resistance.
5. Begin to figure out how you'll run new wire from the spaekers to the head unit.
Double E is offline
Infinity Gold alivenkickin28 ZJ Grand Cherokee Forum 49 05-07-2007 07:37 AM
Infinity gold amp..... NickFeola ZJ Grand Cherokee Forum 1 01-25-2007 12:24 AM
Infinity gold xjzjforme ZJ Grand Cherokee Forum 1 09-08-2006 01:21 PM
Infinity Gold Amp Kyle howard ZJ Grand Cherokee Forum 6 04-30-2005 10:43 AM
Infinity gold amp natedawg ZJ Grand Cherokee Forum 19 08-04-2004 09:55 PM
