Improvements to paint finish - JeepForum.com
post #1 of 16 Old 03-27-2013, 10:10 PM Thread Starter
capcyclone
capcyclone's Avatar
So this isn't necessarily a specific ZJ question, but could apply to any vehicle I suppose. But....my ZJ has a few door dings (no dent) but the other car traded paint onto my door in a few spots.
Anyone have a suggestion of a good product/procedure that worked well for them?
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #2 of 16 Old 03-28-2013, 11:22 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Clay bar
ratmonkey is offline
post #3 of 16 Old 03-28-2013, 05:06 PM
durango-bob
2006 WK
Or get any rubbing compound to polish the other paint off.
durango-bob is offline
post #4 of 16 Old 03-28-2013, 06:49 PM
xcaliber81
Originally Posted by ratmonkey View Post
Clay bar
A clay bar will only remove debris on the paint that washing wont. your best bet is to get a variable speed angle grinder with a mild pad, where i work i use black or darker blue with mothers #2 i believe and it should make it better.
xcaliber81 is offline
post #5 of 16 Old 03-28-2013, 06:52 PM
Dyn0mitemat
Rub it with a tree or some rocks and you wont notice it
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #6 of 16 Old 03-28-2013, 07:42 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If they didn't take clear coat off I've found Clay does the job.
If they did, some meguiars Polish does the trick.
post #7 of 16 Old 03-28-2013, 07:49 PM
billyblooshoes
for what its worth that is not true. clay bars will remove some paint transfer from other surafces in some cases.
billyblooshoes is offline
post #8 of 16 Old 03-28-2013, 07:51 PM
xcaliber81
For some reason ppl will always door the nicest looking vehicle out there and be careful while beside the ****tiest looking turd out there lol. I never get door dings on my jeep but always get them on my 2008 dodge caliber go figure.
post #9 of 16 Old 03-28-2013, 08:18 PM
bob_351c
would never touch my paint with an angle grinder!! If its just a small paint transfer just do it by hand
bob_351c is offline
post #10 of 16 Old 03-28-2013, 08:21 PM
xcaliber81
No no there is special fittings you use with a foam pad.
post #11 of 16 Old 03-28-2013, 08:24 PM
xcaliber81
post #12 of 16 Old 03-28-2013, 08:48 PM
bob_351c
ya, those aren't angle grinders... angle grinders on their slowest speed are usually pretty close to polishers at their highest speed. People burn their paint even with rotary polishers so an angle grinder would murder their paint
and the first one listed was a random orbital polisher
bob_351c is offline
post #13 of 16 Old 03-28-2013, 08:54 PM
leadfootny
I've had good results with either a clay bar or compound as noted above. Make sure to do a good waxing after as both will strip the current wax layer off.
96 ZJ 4.0
98 ZJ 5.9
leadfootny is offline
post #14 of 16 Old 03-28-2013, 09:03 PM
xcaliber81
Yea I know I polish cars for a living I was using layman's terms lol. If you can dial in the speed on the angle grinder to around two thousand rpm's with the proper compound it will work you just need the foam pad and the mount for it.
post #15 of 16 Old 03-28-2013, 09:12 PM
bob_351c
never heard anyone refer to a polisher as an angle grinder.
bob_351c is offline
