Improve Towing capacity? - JeepForum.com
post #1 of 28 Old 07-13-2012, 11:06 AM Thread Starter
MN59ZJ
So I rebuilt my 5.9 engine, now making an estimated 400 ft/lbs of torque... Swapped in a 242HD transfer case... I put a Ford 8.8 in the rear... IRO front & rear long arms, which add 2 beefy cross members, significantly increasing "chassis" strength... I have IRO transfer case skid, a Rusty's fuel tank skid, and obviously, the MOPAR class 3 hitch, all add to chassis rigidity...
So my question is, have I improved my towing capacity? I'd like to get an Airstream trailer.
MN59ZJ is offline
post #2 of 28 Old 07-13-2012, 11:09 AM
porrsher
1994 ZJ
With a good WDH (Weight Distributing Hitch) you'll have no problem. Just make sure you get a good brake controller and keep an eye on the tranny. If it starts hunting gears turn OD off.
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline
post #3 of 28 Old 07-13-2012, 11:26 AM
KingtheZJ
get a truck. for real.
ZJs have no business towing anything close to their 6500lb rating
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 28 Old 07-13-2012, 11:43 AM
Technohead
If anything you have decreased the towing capacity. Light duty passenger vehicles with coil spring suspensions and unbodies constructed mainly of 16 gauge (or less) sheet metal are not tow rigs.
You could reasonably tow a 3,000 lb camper if you run a weight distributing hitch and the trailer has brakes.
-Eric
Technohead is offline
post #5 of 28 Old 07-13-2012, 12:07 PM
PolkaPower
I guess my idea of having a ZJ trucking company is out the window. I was going to get a pet chimp and all.
PolkaPower is offline
post #6 of 28 Old 07-13-2012, 12:30 PM
93zjer
I've towed my 64 el camino around plenty on a car trailer. Not sure what that weighed but I could tow quite a bit more as I could still fly up hills. I have a 4.0 too.
I'm pretty sure that besides your tongue capacity and load capacity it the total weight of your vehicles that really limits your towing capacity, not your drivetrains ability to actually pull the load.
93zjer is offline
post #7 of 28 Old 07-13-2012, 12:51 PM
jtackerman28
The transmission will not hold up to a heavy load like a truck, simple.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #8 of 28 Old 07-13-2012, 12:57 PM
Mickey_D
93zjer almost hit the nail on the head. It has nothing to do with what your ZJ can get moving as to your towing capacity. It has to do with what it can handle in a "HOLY ****!!!" situation.
First and foremost is the front brakes. Or lack thereof. The front brakes on a ZJ are the exact same part number as the front of an XJ. And I think they're also the same on a TJ. Think about that. The TJ was designed to only stop itself. A Wrangler was never really designed to tow anything, hence why U-Haul and such will NOT rent a trailer to put behind them. So Chrysler designed the brakes with that bare minimum in mind.
Then those exact same brakes were stuck on the front of an almost 4,000 pound SUV with the words "Grand Cherokee" glued on the side.
Yeah, good luck with that. The maximum I've ever towed with mine was a little M100 1/4 ton trailer (750lb curb weight) with 660lbs of scrap metal in it. And that was getting squirrely on me descending hills.
I wouldn't tow more than 2,000 pounds behind a ZJ. If some moron ever cuts you off and you have to slam on the brakes, I'd say it's a 50/50 chance the trailer's going to push you aside as it keeps right on going in a straight line (or worse yet a squiggly line with you still attached to the front of it).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #9 of 28 Old 07-13-2012, 01:04 PM
jtackerman28
I've towed a 20 ft ski boat with 31" tires and a lift and trust me that I'd the most I would ever do and it was only for 10 miles tow a motorcycle or a small popup camper or maybe a small boat and call it a day
post #10 of 28 Old 07-13-2012, 01:33 PM Thread Starter
MN59ZJ
Wow, 9 replies and a couple of them are actually useful! Part of the reason I don't come here that often.
For those of you who were helpful, thank you. The grand prize goes to Mickey_D though. The brakes on the ZJ are truly awful, they can barely stop a ZJ by itself. Long before I have my airstream, I'll be swapping in a HP Dana 44 with F-250 brakes (or better) so that will be taken care of. Transmission is the other issue I'll be addressing in a year or two.
For those of you who posted simply to show how "brilliant" you are, you are useless in a forum like this. Most of you have only enough knowledge to make fools out of yourselves. There is no reason to be redundant by buying a chimp, you already have that system covered!
If anyone else has USEFUL information, please feel free to give it.
MN59ZJ is offline
post #11 of 28 Old 07-13-2012, 01:39 PM
KingtheZJ
wait, you are swapping in a HP44 just to have better brakes? holy balls.
if you are that set on towing with it, get the vanco kit or do a wj knuckle swap.
'88 XJ
post #12 of 28 Old 07-13-2012, 01:47 PM
Technohead
More important than the brakes on the vehicle are the brakes on the trailer. If you are relying on the vehicle's brakes to stop the trailer then you have problems. Swapping in bigger front brakes is like putting lipstick on a pig.
Think about what happens when you slam on the brakes. Without trailer brakes all the stopping force gets transmitted through the trailer tongue. Its very unstable. Like trying to balance a pencil on its tip.
Like I said (and somebody else said the same thing), if you want to tow a small camper then use a weight distributing hitch and make sure the trailer has brakes. These are BY FAR the most important tips for SAFE towing. Beyond that you need to pay close attention to transmission fluid temperature but this is not a safety issue.
-Eric
post #13 of 28 Old 07-13-2012, 01:48 PM
KingtheZJ
HEY! don't talk about my girl like that.
'88 XJ
post #14 of 28 Old 07-13-2012, 01:49 PM Thread Starter
MN59ZJ
No, I'm swapping in a HP44 for the same reason I installed everything else... Off-road capability. The brakes are just a side benefit. I only want an Airstream because my wife is too cheap to get a hotel room, and I hate tent camping!
MN59ZJ is offline
post #15 of 28 Old 07-13-2012, 01:51 PM
KingtheZJ
how much lift do you have? whats your plan for the rear axle?
'88 XJ
