i'm swapping a 5.2 to 5.9, anything else i should do while its taken apart? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > i'm swapping a 5.2 to 5.9, anything else i should do while its taken apart?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-13-2010, 02:31 AM   #1
snotrod
hey guys, i'm new to this forum, i tried searching but couldnt really find what i was looking for. i'm in the process of swapping a 5.9 into a 96 5.2, and i wanted to know if there was anything with these motors that usually dont get done that i should do while i have everything apart, anything at all that are buggers with these motors, anything that you can recommend. i dont really need help with the swap, i've done plenty before. just new to the chrysler/jeep motors and any quirks they might have.
thanks in advance!!
Stephan
snotrod is offline   Reply With Quote Quick reply to this message
Unread 03-13-2010, 02:51 AM   #2
JrMechanic
Timing set, plenum gasket (upgrade to a Hughes or APS plate, or make your own), oil pump, and rod bearings if you're in the mood.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/n...pdated-685644/
JrMechanic is offline   Reply With Quote Quick reply to this message
Unread 03-13-2010, 03:49 PM   #3
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
oil pump, water pump, plenum plate.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 03-13-2010, 05:03 PM   #4
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You won't find an easier time to pull the heads on the new motor and inspect the bores and valves. Cost you a set of head gaskets and precious time.
HighLonesome is offline   Reply With Quote Quick reply to this message
