Im getting 40psi oil pressure under a load and only 20 stopped in drive....
#1 | |
Is this going to blow my engine up? I was gonna try some lucas to thicken the oil up. Good idea? Thanks, Joe
1996 Jeep Grand Cherokee Laredo 4.0 4X4 |
#2 |
that's normal.
you're oil pressure is supposed to regulate like that.
Built not Bought #170 My build thread: http://www.jeepforum.com/forum/f197/travis873o-build-thread-1295705/ FOR SALE: ZJ 231 bezel, PM me if you need one. |
#3 |
I think he is reffering to the abnormally low pressure reading. Check your oil first if you haven't, and then I would look at your oil pressure sending unit. Those are a pretty common failure in older vehicles, and if it is that then the reading at your gauge is false. If that isn't the problem I would drop the oil pan and replace the screen on the pump. If that isn't the fix then prolly the oil pump. Gl
#4 |
Resident Audio Guru
Do not add lucas...ever.
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#5 |
Ok, so if I let it idle at 20 psi for any kind of period of time will it do any damage? And why no lucas? I have always sworn by that stuff.
#6 |
Living dead mod
Anything over 10psi at idle is good and requires no action.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#7 |
If you want to make sure you have good pressure hook up a mechanical gauge and check. The oil pressure gauge in your Jeep is not accurate by any means.
#8 |
x2 on testing the sending unit and using a mechanical guage
But I doubt there's anything wrong. If there was a problem, the idiot light and CEL would come on. |
#9 |
is this after the engine has been warmed up or is this under cold startup that you are only getting 20psi
#10 |
Platinum 5.9l, K&N FIPK, Kolak 3" exhaust, SCT Tuned, Flowmaster 50 series, Doug thorley headers, E-Cutout, 180 thermostat, Fastman 52mm TB, Ported Kegger, Stillen rotors |
#11 |
Resident Audio Guru
#12 | |
#13 |
I just changed the oil with 10w30 penz. No additives. Its getting 20 psi at idle after its warmed up.
#14 |
I average about 70 before warmed up, about 35-40 after warmed up at idle and about 55-60 while driving
#15 |
Agreed - 20 at idle is NOT "low."
I had a 91 XJ with the 4.0 HO and at idle in drive it would go below 10. It was never a problem. If you're that worried about it, do as recommended and use a mechanical guage. Otherwise, take the advice of others and call it good - 'cuz it IS good. ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
