im fighting death wobble and losing miserably - JeepForum.com
post #1 of 8 Old 08-23-2009, 11:50 PM Thread Starter
zippome
so as the title says, i am indeed fighting death wobble. its gotten to the point that im avoiding the jeep as much as i can. its like dw is breathing down my neck every second im in it. i got dw as i was going 70 once with my girlfriend and her 4yr old brother in the back and it scared the crap out of me. i really need to fix this before anything bad happens. money is really tight right now so im cheaping out (even though i know i shouldnt). what do you think of this kit? SUSPENSION JEEP GRAND CHEROKEE 99-04 BALL JOINT ENDS :eBay Motors (item 140339219151 end time Sep-10-09 12:11:42 PDT)
if you were in my position, would you go for it? i know cheap parts arent the way to go but i really cant drop $200+ right now.
i got an alignment a bit ago. i have a fresh rancho SS. Bushings, LCA's, and TB are all in good condition. so i figured this was my next step. If anyone thinks i should do something differently, please let me know
thanks
mark
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline
post #2 of 8 Old 08-24-2009, 12:03 AM
iluvtruenos
Check your uppers.
While we were doing my long arms, I noticed tht my upper control arm bushings were disintegrated giving me DW at above 45mph, only with the passenger side front tire. That's the bushing that was shot.
Check your uppers.
Unbolt upper arm one at a time and see if the bushings are good.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #3 of 8 Old 08-24-2009, 12:13 AM Thread Starter
zippome
Originally Posted by iluvtruenos View Post
Check your uppers.
Check your uppers.
thanks a lot, i think ill check that out tomorrow. i figured that the ball joints and tre's and such are all stock and after 150,000 miles, its time to change them anyway. so i think im going to order that set anyway.
if the bushings are shot, where can i get just UCA bushings? is that something kolak would have? also, if one bushing is shot, im just going to replace them all. might as well
zippome is offline
post #4 of 8 Old 08-24-2009, 12:27 AM
iluvtruenos
My TRE's are in god condition, but the joints at the draglink are all shot.
I have about 3in of play in my steering wheel, but no DW even at 85.
post #5 of 8 Old 08-24-2009, 01:01 AM Thread Starter
zippome
so i just read over that listing again and realized it said tie rod ends and outer tie rod ends. can someone explain....
zippome is offline
post #6 of 8 Old 08-24-2009, 01:21 AM
skain8
skain8's Avatar
Would I buy that junk for my WJ, no. But if you're in a bind, I guess your options are limited....
The joint ends are for the tie-rod and draglink. They don't refer to them as draglink ends. Looks to be the complete set of ends.
I see you have the Zone 4" kit. From the description, it comes with only fixed lower control arms. That gives you zero adjustability in terms of caster. If your caster is off, it can contribute to DW.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #7 of 8 Old 08-24-2009, 05:51 AM
iluvtruenos
Plus, doesn't it come with a DPA and DTB?
Check the DTB for stress. Or, get a JKS and use your stock pitman arm.
post #8 of 8 Old 08-24-2009, 07:34 AM
vosevichs
I'd check that front end thorughly. Track bar, control arm bushings, etc, etc. Then replace what's needed.
Scott Vosevich
vosevichs is offline
Death Wobble got me!!!! coldcanuck ZJ Grand Cherokee Forum 8 04-03-2009 09:07 PM
Death Wobble Help!!! RubiconR6 ZJ Grand Cherokee Forum 1 03-22-2009 01:41 PM
WOW! Death wobble Mike Cooper ZJ Grand Cherokee Forum 36 04-10-2008 08:33 PM
Death Wobble subzero32 ZJ Grand Cherokee Forum 4 07-25-2006 09:52 PM
Death Wobble or?! laxwarriors21 ZJ Grand Cherokee Forum 4 04-24-2005 06:31 PM
