Ignition upgrade done...now Jeep dies - JeepForum.com
post #1 of 14 Old 06-05-2013, 07:54 AM Thread Starter
brewcity1
Hey guys...I got Kolaks ignition upgrade about 2 months ago...now, my 9er dies intermittently...just shuts off. I traced the problem back to the MSD coil that comes with the package. All I have to do is wiggle the wire under the coil a bit, and it fires right up. Does this sound like a bad connection...or bad coil? If its a bad connection...how to I go about replacing it?
Thanks for the help!
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #2 of 14 Old 06-05-2013, 08:28 AM
PolkaPower
That's part of the upgrade. Saves gas!
Sounds like the wire is broken partially. Make sure your grounds are clean and tight first. If it's still bad then you will probably have to splice the wire.
PolkaPower is offline
post #3 of 14 Old 06-05-2013, 08:32 AM Thread Starter
brewcity1
LOL...I like that one!
Lovely...splicing is the LAST thing I wanted to do.
So it sounds like your leaning towards a bad connection, as I am.
I just didnt know if this was a symptom of a bad coil.
I'll check the grounds, and go from there...any advice on what and where to cut, and how to go about this? I am just worried I will make it worse, or wont be able to get it back to working correctly. I guess I dont have much of a choice...as it doesnt run now!
Thanks for the help.
post #4 of 14 Old 06-05-2013, 08:51 AM
PolkaPower
Well a bad coil wouldn't suddenly work when the wires are fiddled with in my experience. That is usually a connection. You can go get another coil from a jy and test it out. Don't pull the wire off of the coil while the truck is running to see if it's working or not. That was like releasing Rayden with lightning bolts shooting out all over.
Just to be clear, you are talking about the wire harness with the clip and NOT the plug wire right?
post #5 of 14 Old 06-05-2013, 09:39 AM Thread Starter
brewcity1
That does NOT sound pleasant!!
Yes...I am talking about the wire harness under the coil...not the plug wire going to the dizzy. Problem is...I am not sure if its the aftermarket Accel 140021AH Ignition Coil Adapter Harness that came with the kit...or the original wiring going into that harness...or both!
post #6 of 14 Old 06-05-2013, 10:35 AM
PolkaPower
Well it wasn't an issue before right?
post #7 of 14 Old 06-05-2013, 10:45 AM Thread Starter
brewcity1
Good point...it was not an issue before the upgrade. But everything was stock.
So...I guess I will just check the grounds, and clean the connections...if its still an issue...I'll get another pig harness for $20.00 and try that, as you mentioned...everything worked before...so its probably NOT my original wiring that is bad.
post #8 of 14 Old 06-05-2013, 06:06 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The original harnesses {what you are plugging the accel harness into} have been known to give a problem on jeeps once they have been disconnected . Check it out before you drop the cash. Also, did you disconnect the negative terminal on the battery before installing?
Originally Posted by HighLonesome
coralman is offline
post #9 of 14 Old 06-09-2013, 01:28 PM Thread Starter
brewcity1
I did disconnect the negative battery during the initial set up and installation, yes.
So I got a new Accel wire harness for the coil...and noticed that there is a little red tab in the connection that goes to the coil on the harness...is that supposed to stay in there, or come out? However...I did NOT disconnect the battery when putting on this new harness.
I didnt take the tab out during the initial swap...but took it out with this new one.
Is it supposed to stay in there?
post #10 of 14 Old 06-09-2013, 01:34 PM
coralman
coralman's Avatar
Like a pull tab? It may be a connector lock.
coralman is offline
post #11 of 14 Old 06-09-2013, 01:46 PM Thread Starter
brewcity1
Its kinda like that...I'll snap a pic.
post #12 of 14 Old 06-09-2013, 10:14 PM Thread Starter
brewcity1
I talked to Kolak...he said the tab is to stay in...so I put it back in.
Guess I'll see if she keeps running.
post #13 of 14 Old 06-10-2013, 06:25 AM
Jeep318
How was the ignition system before you put the replacement parts in? Did you redo it as an Upgrade or did you have faulty components? When it does run did you notice any sort of performance gain at all over the factory setup? GL
Jeep318 is offline
post #14 of 14 Old 06-10-2013, 07:29 AM Thread Starter
brewcity1
The ignition was all stock and working without any problems...I redid it as an upgrade since I was doing a tune up anyway. I did notice a difference...quicker start up, and better throttle response and smoother idle...but that may be do needing a tune up for awhile...but the ignition kit from Kolak is a great upgrade, and I do recommend it. I think I just had a faulty wire harness...because I got to work today without any issues at all. Hopefully it stays that way, and I wont have to replace my Crankshaft Position Sensor. Hope this help!
