Ignition switch wont turn - JeepForum.com
post #1 of 11 Old 08-10-2009, 06:16 PM Thread Starter
abe51
2000 Grand Cherokee 6cyl auto sometimes when I try to start my car the ignition key wont turn.I can hit the key with my hand 2 or 3 times and it will turn. Does anyone know where I can get a blue print of the steering column. Something broken and I would like to fix it. Thank You
abe51 is offline
post #2 of 11 Old 08-10-2009, 06:23 PM
newfieZJ
jeepslimited.com , sign up , sign in , you'll be able to download the factory service manual free . It will have the specs and pics you want . The parts lists also make for nice references
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 11 Old 08-10-2009, 06:42 PM
micifus
Original GC'er
micifus's Avatar
It's most likely your key cylinder, its a common problem. You should just have to take the cover around the steering colum off, take out the key switch(which contains the key cylinder). This main require some special tools most likely saftey torx. The new key cylinder should have instructions on how to install it.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #4 of 11 Old 08-11-2009, 02:03 AM
sandman
had to replace the cylendar on my ZJ. my moms WJ did the same thing yours did but it was years ago and was replaced under warranty. i say fix it ASAP, my moms was sticking for a few months and eventually left her stranded.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 11 Old 08-11-2009, 06:57 AM
malibubts
Thanks Newfire! A little off topic but that site is really nice.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #6 of 11 Old 08-11-2009, 07:10 AM
Mud_Pig
1997 XJ Cherokee
Just a quick heads up. The ignition cylinder for this is not cheap (part # 05083915AB)
But if you know you local dealer parts guy, have him use cylinder # 04746666. It works with all TJ's 97+ XJ's and 98+ Grands (ZJ and WJ)
It is a big differance in price (about 1/2)
97XJ with a few mods
8.5" long arms and 35's
Build Thread
Mud_Pig is offline
post #7 of 11 Old 08-11-2009, 03:33 PM Thread Starter
abe51
Hay guys thanks for the tips,that will help alot.
abe51 is offline
post #8 of 11 Old 08-12-2009, 07:24 AM
mikealdo
Remove the cylinder, take it to a locksmith and get it re-keyed. They actually don't change the keys, but change the springs in the cylinder. Had the same problem, until it would not turn. It cost me $30, it was done in an hour. The locksmith said it would last 100,000 miles. I hope the rest of it does.
mikealdo is offline
post #9 of 11 Old 08-12-2009, 12:52 PM
Double E
Double E's Avatar
Do the springs & cylinder yourself: http://www.jeepforum.com/forum/f310/key-ignition-lock-issue-key-no-turn-597301/
Remove & clean everything from the old cylinder up, writing down the codes on the tumbler parts in order as you remove them and reassemble into the new cylinder as they are taken out. Use the new lube that comes with the new cylinder and yes...good for another 100k miles.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #10 of 11 Old 08-13-2009, 07:49 PM Thread Starter
abe51
Thanks, yall made what I though might be difficult sound a lot easier.Thanks for the info. I wish they had a site like this for boat repair.(just kidding)
abe51 is offline
post #11 of 11 Old 09-15-2009, 08:06 PM Thread Starter
abe51
Quick update Mikealdo I took your advice the lock smith cost me $8.00 Works great Thanks.
abe51 is offline
Key Won't Turn - Stuck Ignition Switch - FIXED viper1993 ZJ Grand Cherokee Forum 6 05-30-2017 05:38 AM
93 ZJ Ignition Switch? turn and no crank Snakeyes98 ZJ Grand Cherokee Forum 6 03-24-2013 11:26 AM
02 Wj Bizarre turn signal wont turn off mountcharles ZJ Grand Cherokee Forum 0 05-05-2009 02:51 PM
*Urgent* 99 Grand ignition key wont turn, stranded. Rexor ZJ Grand Cherokee Forum 12 09-19-2008 08:07 PM
HELP-KEY WON"T TURN-IGNITION SWITCH?? Myrtle Beach ZJ Grand Cherokee Forum 5 08-20-2004 07:14 PM
