Ignition Switch - JeepForum.com
post #1 of 6 Old 08-23-2005, 08:53 PM Thread Starter
fozman68
Ignition Switch
I just bought a 1993 GC, in which the ignition switch was popped, so that it could be repoed. I test drove the Jeep, and it ran great, just had to start it with a screwdriver. Now, the security alarm has gone off, I disengaged that, using alarmtech site. But it still won't start. I'm thinking that is from the Ignition being popped, and that all Chryslers, and Jeeps, had security keys. Has anyone ran into this problem, and would anyone know an easy fix? Thanks, Ken
fozman68 is offline
post #2 of 6 Old 08-24-2005, 12:18 AM Thread Starter
fozman68
were the keys coded in 1993?
fozman68 is offline
post #3 of 6 Old 08-24-2005, 12:26 AM
Decipticon
Im pretty sure they werent. You can buy blanks for cheap on ebay too.
Jesus is coming. Look busy.
Decipticon is offline
post #4 of 6 Old 08-24-2005, 12:32 AM
driabyor
driabyor's Avatar
1994 ZJ
no coded keys
i think that the alarms are kinda automatic
mine just turns on
unless you unlock the door then the alarm goes off and disables the vehicle
i really dont think that the alarms can be made not to function
the door locks and the rear hatch disable the alarm
if you lock the door then that turns on the alarm
the easiest fix would go buy a new lock cylinder
take your vin # an they can make the key the same as the vehicles was...
then it will also fit the door....
wally world broke mine .. i think it was around 100 bucks but the parts person keyed it to fit the jeeps original keys
someone else may have a better answer and this may not all be right but
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 6 Old 08-24-2005, 12:34 AM
driabyor
driabyor's Avatar
1994 ZJ
oh got my 100 bucks back from wally also
5.2 liter 242 :)
driabyor is offline
post #6 of 6 Old 08-24-2005, 06:16 AM Thread Starter
fozman68
I'm going to get the new ignition today, but I did disable the alarm. there is a way, and I did it, because way to many people have had the same problem. Had to ground out a wire, that goes to the drivers door lock mechanism. (purple and yellow). It was going off, when I got the vehicle, and I tried to reset it, thru using pass. door lock, and tailgait lock, but it still went off. Lights would flash, horn would honk, and dash had securtiy flashing. Thats why I was told to disable the alarm. told a faulty wire somewhere. So, what happens when alarm goes off? just sound and sights, or will it disable the Jeep? Thats what I'm trying to figure out.
fozman68 is offline
New ignition switch 88mudder WK Grand Cherokee & XK Commander Forum 1 12-14-2010 01:39 PM
here to buy ignition switch? georged ZJ Grand Cherokee Forum 0 08-15-2009 06:19 AM
ignition switch. sandman ZJ Grand Cherokee Forum 6 03-24-2009 12:28 AM
WJ ignition switch-HELP Myrtle Beach ZJ Grand Cherokee Forum 3 09-11-2004 03:40 PM
ignition switch tbone31 ZJ Grand Cherokee Forum 1 06-29-2003 03:50 PM
