Ignition short - JeepForum.com
post #1 of 4 Old 03-08-2012, 01:43 PM Thread Starter
stevetc99
Ignition short
I have a short somewhere that is causing my starter relay to blow. It did it once i changed the started and horn relay lights came on but i turned the key and it blew that relay too. Where do you think the short could be? How should i go about fixing this?
stevetc99 is offline
post #2 of 4 Old 03-08-2012, 01:55 PM
Oldfrog
2007 WK
I have no idea, but here's one test:
Disconnect the hot wire from your starter and tape up the end so it doesnt short out. Then turn the key. If it doesnt blow the relay...it's the starter.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 4 Old 03-08-2012, 02:00 PM Thread Starter
stevetc99
if it doesnt blow the relay then its the starter itself and i need to replace it?
post #4 of 4 Old 03-08-2012, 02:16 PM Thread Starter
stevetc99
Ok so I messed around with the relays and put the horn one in place of the starter one again and now both the horn work and the lights in the car come up but i can hear the starter clicking and then spining then clicking again then it just spins and nothing happens
ignition , short
Short to or from ignition switch edpmedic ZJ Grand Cherokee Forum 1 12-09-2011 05:18 PM
fog light short cut sullivanpunk ZJ Grand Cherokee Forum 2 02-11-2009 03:24 PM
Short somewhere on 4.0 new2jeepmn ZJ Grand Cherokee Forum 1 12-07-2008 02:24 PM
is it a short? freak4jeeps ZJ Grand Cherokee Forum 2 04-13-2006 05:29 PM
short arm ZJ_Jeep ZJ Grand Cherokee Forum 2 06-17-2005 10:00 AM
