Quantcast Ignition Pulse Wiper Module Roasted Again - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ignition Pulse Wiper Module Roasted Again
Old 02-15-2007, 09:50 PM   #1
micifus
Original GC'er
micifus's Avatar
For those of you who read my Ignition Pulse Wiper Module repair post are fimilar with this problem.
http://www.jeepforum.com/forum/f13/ignition-pulse-wiper-module-repair-project-279739/
Started the jeep this AM turned the wipers on to clear snow snow and then I smelled burning electronics, turned them off then back on. They stayed on would not shut off, put it to the off position push the fluid and the stopped dead in the the middle of the windshield, and now no longer return to resting position . The added stress from ice and snow and not being able to return to the home position seems to draw more current through the circuit causing this problem. Soldering it backup now
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 02-16-2007, 05:56 AM   #2
greasefingers
1994 ZJ
I seem to have the worse luck soldering it like you have done. I can’t seem to get the solder to stick on the flat copper ribbon/wire. Therefore I usually go to the nearest component solder joint, and attach a jumper at these two points (indicated by the arrows)
I do not have a decent photo editor. I used MS Paint and therefore it looses the color converting the file to bitmap. I then tried to use MS Picture Office Picture Manager. Am I stupid or is it impossible to add things like arrows in this program? Its OK to call me stupid … my wife does it all the time.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 02-16-2007, 06:06 AM   #3
micifus
Original GC'er
micifus's Avatar
Yeah the board is hard to solder to there is a coating over all the electronics even when scrapped off there is some left over. I just scrap off the coating, apply heat to the tip to the trace and let it get nice and hot, then lay a stripped piece of wire along the trace and apply the solder. I am pretty good at it although you cant tell from the pics and the was a half assed job. I would suggest cleaning the surface well with a fine grit sand paper, then rubbing alcohol, the purchase some rosin apply a little to the trace and heat it up to it boils off, then apply the solder it will stick to copper like glue and look really nice! The important thing to remember is the soldering iron is not a paint brush solder will flow towards heat so put the tip where you want solder to flow to and apply the solder to the opposite side letting it flow to the tip
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 02-16-2007, 06:09 AM   #4
greasefingers
1994 ZJ
What really pisses me off is when you try to apply solder to something other than copper wire, and the solder just rolls off … like it was mercury or something.
Cheers Steve
Old 02-16-2007, 06:23 AM   #5
micifus
Original GC'er
micifus's Avatar
haha yeah I used to get soooo annoyed with soldering then I took a class on it and I love it! It does that because the surface is not clean, sand paper, rubbing alcohol, and straight rosin are you friend and dont be afraid to really heat that surface up.
Gotta goto work now yay!
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 02-16-2007, 07:00 AM   #6
greasefingers
1994 ZJ
What is straight rosin? Is this the solder type composition?
I do use flux.
Cheers Steve
Old 02-16-2007, 07:37 PM   #7
micifus
Original GC'er
micifus's Avatar
I do use flux.
same thing is as flux I was thinking rosin core solder at the time dont know why I didnt say flux.
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 02-16-2007, 08:39 PM   #8
greasefingers
1994 ZJ
Flux you
Cheers Steve
Old 02-28-2007, 11:16 AM   #9
QuadraTokn
1930 WJ
my delay wipers stopped working and remembered your thread from last year. once i found the module, i was done in 20 minutes. thanks for saving me $30!
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 12-11-2007, 11:04 PM   #10
Aceladriver
Ditto on that - of course I found this post right after I figured this out on mine. I used fine buss wire like you did.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline   Reply With Quote
Glock Forum
