Ignition Pulse Wiper Module Repair Project - Page 5 - JeepForum.com
post #61 of 87 Old 01-03-2011, 08:21 PM
stephen3776
Guess we are all a bunch of rocks, but looks like reviving this old thread for those of us who cannot use the search function was a great help.
stephen3776 is offline
post #62 of 87 Old 01-06-2011, 04:45 PM
tsifreak
Just got it done in my ZJ. I soldered in a 18g wire came out great. Wipers work in all positions now mint! With that wire in there now I dought I will ever have a problem again.
tsifreak is offline
post #63 of 87 Old 01-18-2011, 09:29 AM
phbrown
1994 ZJ
Thank you.
Just did this yesterday to celebrate MLK day
However, now it appears that I only have one speed setting for all settings. Oh well
1994 Jeep Grand Cherokee Laredo| stock| 231 transfer case| 4.0L
phbrown is offline
post #64 of 87 Old 01-19-2011, 07:59 AM
78fbta
I had to do mine a couple days ago,i used a piece of wire and JB weld
Works perfect,never would have found it w/o the help of this thread.
Thanks for the writeup.
78fbta is offline
post #65 of 87 Old 03-04-2011, 04:45 PM
chich
Thanks to the original poster for this information and excellent instructions.My module had the problem in the exact same location.As stated,repair took all of twenty minutes.My wipers now function on delay settings and return to park position when turned off.
chich is offline
post #66 of 87 Old 04-23-2011, 06:58 PM
FortCollinsZJ
since this thread is five years old i dont mind chiming in with my two cents. my intermittent settings (all of them) havent worked since i bought my 93 grand a few years ago. only low and high worked and every delay setting ran at the ''low'' speed and would stop at any position when i turned them off. in the last few days, i replaced the motor which was not the problem as i was misinformed, then the multi function stick which actually changed one thing, now the wipers will not park at the bottom, but only return to vertical. i cannot see any burned traces on the intermittent control module so i tried just plugging the two harnesses together which yielded smoke from the multi function stick but no different action, still only parking vertically. i am now going to check the ecm connection harness as one of you stated earlier that it could be the culprit. i will update as, who knows, maybe i will be the first to be experiencing something other than a torched board or loose connection.
FortCollinsZJ is offline
post #67 of 87 Old 04-23-2011, 08:28 PM
Foundrydude
Great thread!!
It was bumped while I was sitting around waiting for friends to get off work for beers. 15 minutes later I got fully functional delay wipers that park themselves instead of just lo/high and no parking.
Tip for noob solderers......mine was bad in the exact same place as the OPs. It's hard to solder onto the flat circuit board but easier to solder onto those posts. Follow the circuit and make a one inch jumper wire from post to post across the burned spot. Less risk of dripping solder onto a nearby circuit, causing a short.
Foundrydude is offline
post #68 of 87 Old 08-31-2011, 09:24 AM
trotter88
Awesome!!!
THank YOU,
This was driving me crazy, Took 15 min and fixed my intermediate wiper issue.
trotter88 is offline
post #69 of 87 Old 12-21-2011, 10:52 PM
hdrocknroll
I have been researching, and found what the problem might be with my wipers, and now, I might have found a fix.
I will take the module apart and see what I see.
Thanks for the post!!!
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #70 of 87 Old 12-23-2011, 10:37 PM
hdrocknroll
Well I found burned spot ,soldered it ,now they are fully functional.
Fantastic Info !!!
Thanks a lot
post #71 of 87 Old 02-18-2012, 02:30 PM
L0G1K
Just did this fix and everything is working fine now. Thanks a lot, took me 15 minutes and cost nothing, that's fixes the way I like it!
L0G1K is offline
post #72 of 87 Old 02-19-2012, 09:36 AM
stephen3776
Just a side note, my 93 ZJ was not the wiper module, but dirty contacts on the wiper switch which is much more fun to get out and apart. Cleaned up the contacts and it has been working perfectly ever since.
post #73 of 87 Old 06-16-2012, 11:06 PM
MaraJadeSharpie
1995 XJ Cherokee
Just had to comment, as I employed this fix this morning with 100% success! Found a burned out spot on the module, fixed it up in 20-30 minutes, as stated. Beyond happy.
And yes, the instructions were perfectly applicable to my Cherokee.
MaraJadeSharpie is offline
post #74 of 87 Old 09-10-2012, 11:39 AM
mtsgsd
Great thread! I fixed my module yesterday from this thread. There was a trace burned out exactly as described. The delay still doesn't work on mine, but at least it parks now!
mtsgsd is offline
post #75 of 87 Old 09-15-2012, 10:39 PM
hdrocknroll
Nine months later and still, fully functional
windshield wiper
Ignition module biff342 ZJ Grand Cherokee Forum 0 01-28-2009 08:42 PM
Ignition Pulse Wiper Module Roasted Again micifus ZJ Grand Cherokee Forum 9 12-11-2007 11:04 PM
Wiper pulse motor mitak1 ZJ Grand Cherokee Forum 3 03-05-2007 05:25 AM
Intermittent Wiper Module? xxNASTYxx ZJ Grand Cherokee Forum 4 10-24-2006 08:09 PM
where is wiper module on 2004 z28wiz ZJ Grand Cherokee Forum 4 07-08-2005 06:15 PM
