Quantcast Ignition Pulse Wiper Module Repair Project - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ignition Pulse Wiper Module Repair Project
Old 07-17-2006, 06:21 AM   #16
CoyoteCruiser
I thought it worked putting in a new relay but the other day it was raining and it started acting up again. They don't return to home position and when you have them on delay the wipers got 3 times across the wind shield before they turn off. I don't know what else to do.
Bob
CoyoteCruiser is offline   Reply With Quote
Old 07-17-2006, 11:18 AM   #17
micifus
Original GC'er
micifus's Avatar
Did you hunt down the ignition pules wiper module? It was under your hood wasnt it?
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 07-17-2006, 08:29 PM   #18
CoyoteCruiser
No I didn't I just replaced the relay. I don't know what to look for on a 97 GC.
Bob
Old 07-17-2006, 10:25 PM   #19
micifus
Original GC'er
micifus's Avatar
Body Control Module
BCM
Attached to the Junction Block, under the driver's side of the instrument panel.
The BCM utilizes integrated circuitry and information carried on the Programmable Communications Interface (PCI) data bus network along with many hard wired inputs to monitor many sensor and switch inputs throughout the vehicle.The BCM supports many body electrical features such as Interior Lighting, Exterior Lighting, Intermittent Wipers, Remote Radio, Accessory Delay, and Heated Seats.
That seems to be the answere, did look into that?
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 07-18-2006, 06:12 AM   #20
CoyoteCruiser
No, I never heard of it.
thanks
Bob
Old 07-18-2006, 04:24 PM   #21
CoyoteCruiser
I think I found it I see a thing with wire clips going in to it. No what do I do? lol
Bob
Old 07-18-2006, 08:50 PM   #22
micifus
Original GC'er
micifus's Avatar
Well with the BCM im not sure you might just need to replace it. Umm take it out and take some pics, see if you can open it up take some pics of it. Im not sure its a serviceable part. I think they can be rebuilt...
this might be the same on in the jeep I dont know
http://cgi.ebay.com/ebaymotors/Rebuilt-96-97-CHRYSLER-CARAVAN-BCM-Body-Control-Module_W0QQitemZ110009465354QQihZ001QQcategoryZ335 96QQcmdZViewItem
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 10-23-2007, 06:47 PM   #23
godeephammer
Thanks, with your directions I fixed the delay module on my 95 GC. It works like a champ again.
godeephammer is offline   Reply With Quote
Old 10-23-2007, 10:01 PM   #24
micifus
Original GC'er
micifus's Avatar
Nice Glad to see this get resurrected again, I just fixed all the links to the pictures, they are now hosted at JF.com so they should always be there.
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 10-24-2007, 05:50 AM   #25
CoyoteCruiser
Mine are still acting up I heard that it is in the multi function switch (turn signal wiper control dimmer) is this true on a 97 GC?
Old 10-24-2007, 08:57 AM   #26
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Good find and nice writeup.
HighLonesome is offline   Reply With Quote
Old 10-24-2007, 09:01 AM   #27
micifus
Original GC'er
micifus's Avatar
In the newer ZJ I believe the problem lies in the Body Control Module (BCM). If you have a way of swaping this out with another BCM I would try this first.
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 10-24-2007, 09:27 AM   #28
CoyoteCruiser
Where is it located and where do I find it? I have no Idea.
Bob
Old 10-25-2007, 07:46 PM   #29
Aceladriver
Of course I found this thread after I repaired mine!
The picture of your module with the red square was exactly what mine looked like.
Wipers would work on high and low but would not park or work on intermittent.
I soldered a piece of thin gauge buss wire from terminal to terminal to bypass that section.
For anyone reading this writeup - Just don't make the same mistake I made when testing it.
I decided to install and test the bare board before I put the box back together.
Good idea except it was dark out and I installed using a flashlight.
I didn't notice that the inside of the connectors were not divided between the slots so two of the long flat board pins contacted each other inside the connector.
It popped the buss wire right off it when I turned the ignition on.
After the re-repair and installation with the housing I had park but never got intermittent out of it again. Not sure if I zorched the component that controls the timing or if it was already shot before I messed up.
So put it back in the housing before you test it.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline   Reply With Quote
Old 10-25-2007, 10:08 PM   #30
micifus
Original GC'er
micifus's Avatar
The reason the traces burn up is due to a surge in current typically cause by something inhibiting your wipers from moving. I burn the module out twice in one week during the winter by using my wipers with a lot of snow on the windshield. the snow prevented the wipers from moving and cooked the module, Check you linkage and wipers make sure there is not hindering the movement of the wipers.
My next project is to make a fuse to protect this module
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
windshield wiper
Glock Forum
