Quantcast Ignition Pulse Wiper Module Repair Project - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ignition Pulse Wiper Module Repair Project
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 06-04-2006, 09:12 PM   #1
micifus
Original GC'er
micifus's Avatar
Wipers not working right? Will they only work on high or not return to there orginal postion when you turn them off? Well thanks to jeep946, he informed me it was my Ignition Pulse Wiper Module. This a 30 dollar part but, you might be able to save some cash like I did and fix it your self. Here is what was wrong with mine and what I did to fix it.
The module is located under the drive side kick panel, you will need to remove 2 screws, the two connectors, and then it is just velcroed on. It will look like this.
There is a few plastic clips that can be opened useing a flat head screw driver, try not to break them like I did After you open the box there will be a board in it like this.
There are more plastic clips holding the board in the box and it can be easily removed useing a flat head screw driver. Be careful not to bend the connector pins when you pull it out.
You can see by the red square one of the traces has burned up. Something different might of happened to yours but you should be able to tell be inspection if a component or trace has burned up. I repaired the trace on mine with a pice of striped wire and some solder, not my best soldering job ever but it did the trick.Also be aware that there is a protective coating over all the electronics that you will need to gently scrape it off if you want to do any soldering.
Now just put it all together and reinstall!
The whole job took about 20 minutes and saved me 30 bucks, a wroth while DIY project!
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Old 06-04-2006, 09:47 PM   #2
cj3a
Junior Member
cj3a's Avatar
woohoo, mine wont retract, I will inspect next weekend, thanks
cj3a is offline   Reply With Quote
Old 06-04-2006, 09:56 PM   #3
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
You can see by the red square one of the traces has burned up. Something different might of happened to yours but you should be able to tell be inspection if a component or trace has burned up. I repaired the trace on mine with a pice of striped wire and some solder, not my best soldering job ever but it did the trick.Also be aware that there is a protective coating over all the electronic that you will need to gently scrape it off if you want to do any soldering.
Lookie Pictures
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline   Reply With Quote
Old 06-04-2006, 10:04 PM   #4
micifus
Original GC'er
micifus's Avatar
HAHA I played around with it for like 10 minutes and couldnt get it to work. How did you do that? I clicked the insert picture button but it didnt work. Do you need to be a surpporter? Oh and you forgot the bottom one
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 06-04-2006, 10:40 PM   #5
jeep946
well i am glad to hear that you got your wipers fix. thanks for the spot light at the top of the page. have a good one
94 Grand Cherokee, 4.6 stroker, 7 inch custom long arm kit, 33x12.50x15 Firestone destinations m/ts, flow-master 40 series, magnaflow high flow cat, locked front and rear, super axle kits front and rear, pioneer head unit, CB on channel 10, and a B&M built transmission, switched from a 231 to a 242, 2000 Grand Cherokee steering and knuckles and brakes, no abs, wildwood adjustable proportioning valve, and lots more
jeep946 is offline   Reply With Quote
Old 06-04-2006, 11:26 PM   #6
micifus
Original GC'er
micifus's Avatar
Hey no prob, if it wasnt for you I would of droped 50 plus on the blinker switch arm and module, and still be stuck with borken wipers
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 06-05-2006, 06:26 AM   #7
greasefingers
1994 ZJ
Nice work and thanks for the write-up & pics. I am sure someone(s) will benefit from this.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 07-12-2006, 03:47 PM   #8
CoyoteCruiser
I looked on my 97 Grand Cherokee and there isn't ant thing there. Where else would it be?
Bob
CoyoteCruiser is offline   Reply With Quote
Old 07-12-2006, 05:57 PM   #9
Decipticon
good job with the write up, now i have somewhere to send people when they ask.
The fix has been floating around for a while, its kinda amazing nobody wrote it up before I thought about doing it when i made the fix, but i have no digi camera, and im pretty lazy to boot.
Jesus is coming. Look busy.
Decipticon is offline   Reply With Quote
Old 07-12-2006, 06:18 PM   #10
micifus
Original GC'er
micifus's Avatar
Bob
Hmm it should be right under the kick panel left of the brake it takes 3 screws to take it off, maybe they tucked it up under some where. Anyone with a 97 zj know where it might be???
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
Old 07-12-2006, 06:18 PM   #11
dpierson
Bob
You have to remove the kick panel and it might be tucked up higher (mine was). It also might be wrapped in the grey foam with the sticky backing that they used int he factory around alot of the harnesses.
Dan
Traded 8/9/07
[SIZE=1]Black 94 ZJ Laredo 4.0L 42RE/NP231 Command Trac
Sylvania Silverstars, Alpine CD Head Unit, Pioneer 3-Ways in the Doors, Blacked Out Grill, Kolak Exhaust, Clear Corners, Bilstein Shocks, Gas Tank Skid, Rear Hitch, Hitch Wiring, TC Skid, Hellwig RSB, Military FSB, Brembo Front Rotors, OME SS, B&M Supercooler, RE Tie Rod, Limited Power Leather Seats, 30x9.5 Toyo Open Country ATs, Optima Red Top
Next Mods: Upgrade Battery Cables, Sliders, Black Steelies, 3" Lift, Rear Locker, Bumper, HO Alternator, Winch, Driving Lights[/SIZE]
dpierson is offline   Reply With Quote
Old 07-12-2006, 06:27 PM   #12
Decipticon
From what I remember from when I was asking about mine, they changed the design in 95 or so. 93-95 are in the kick panel. 96-98 are under the hood somewhere, sorry I dont really know any more, I was focused on what applied to mine.
Old 07-12-2006, 06:29 PM   #13
Decipticon
Ok I felt ambitious. But its kinda bad news for you 96+ guys.
http://jeepforum.com/forum/showthread.php?t=129039&highlight=wiper+delay+modu le
Old 07-12-2006, 07:43 PM   #14
CoyoteCruiser
Thanks guys I got it fixed. I switched a relay under the hood took the one for the A/C out and put it in the wiper and it works it goes back to the normal position and the delay is back. I will stop at the dealer tomorrow and get a new one.
Bob
Old 07-13-2006, 12:20 AM   #15
micifus
Original GC'er
micifus's Avatar
Well I am glade I took all those pictures and wrote it all up for no good reason
32"x11.5" BFG A/T
4" Lift
2005 Honda TRX450R
windshield wiper
Glock Forum
