ignition locked help! - JeepForum.com
post #1 of 4 Old 06-22-2003, 03:05 PM Thread Starter
dman1911
I can't turn the key to start the car. The steering wheel is also locked I have jiggled the wheel (relentlessly) back and forth for an hour and the ignition won't unlock. I have rocked the car pumped the brakes and all. Any idea how to unlock it?
These seems like a simple problem but I can't figure it out.
Thanks!
dman1911 is offline
post #2 of 4 Old 06-22-2003, 04:05 PM
sn0b0ards
put the key in and hit it with a block of wood a few times.
one of the pins in the ignition is probably stuck.
that happened to my friends car once. try it.
Robert
sn0b0ards is offline
post #3 of 4 Old 06-23-2003, 04:39 PM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
Not much is un-fixable if you have a good block of wood handy.
Key might be worn down, also. if that is the case take your VIN to the dealer and they can cut you a fresh key for about $7
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
post #4 of 4 Old 06-23-2003, 09:10 PM
Lodgepole
Sometimes when you have a little turning pressure on the steering wheel when you turn the key off, it won't turn on next try. Simply put a good turning pull on the wheel first one way and then the otherwhile trying to turn the key. Works for me and worked on my neighbors exp.
Lodgepole
Lodgepole is offline
Grand Cherokee Ignition Switched Locked wojenski ZJ Grand Cherokee Forum 28 06-02-2012 02:32 PM
Has your WK ever locked you out? jason915 WK Grand Cherokee & XK Commander Forum 6 12-09-2009 11:45 AM
Ignition locked and stuck in a Parker lot plllleeeaaaassse help!!!! ef1992 ZJ Grand Cherokee Forum 8 07-22-2009 08:20 AM
Grand Cherokee Ignition Switched Locked wojenski ZJ Grand Cherokee Forum 4 02-14-2006 02:21 AM
D35 locked 01grander ZJ Grand Cherokee Forum 11 04-07-2005 10:05 AM
