Ignition Coil Failure - JeepForum.com
post #1 of 12 Old 08-28-2006, 10:34 PM Thread Starter
crcsjeep
I have a '94 JGC Larado 5.2L. I have been through (5) ignition coils this year. It keeps on burning out every 200-300 miles. Replace the ignition coil, and runs like a dream (until it blows again). Anyone have any ideas for the cause? Tried just about everything, even repair shop says nothing is wrong. HELP!
crcsjeep is offline
post #2 of 12 Old 08-29-2006, 05:16 AM
driabyor
driabyor's Avatar
1994 ZJ
i have 2 coils on mine.. the original that shot craps twice. and seeing how jeep decided it needed bolts that where 4 foot long. i zip tied the new one next to the old one.. haven't had any problems since... the only reason i zip tied it was .. Boonie fix late night get me the hell out of this town.... Oh it's been zip tied for about 3 years now
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 12 Old 08-29-2006, 06:13 AM
Double E
Double E's Avatar
Shot in the dark here but I wonder if there's a contact that's weak (ground maybe?) and causing the coil to work 10 times as hard to keep up with demand.
No experience with where to look but I would be searching desperately for a broken ground strap, bad connection to anything or some other conxn that's draining/robbing power.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 12 Old 08-29-2006, 06:21 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I think Double E is onto something here. Replace your cap, rotor, wires, and plugs.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 12 Old 08-29-2006, 07:36 AM
micifus
Original GC'er
micifus's Avatar
you could try the old pull the jeep into a dark garage at nigth and fire it up trick. Look for electrical Arcs, wires may be worn and something could be arcing to ground. Ground being your engine or any other chassis part. Replcaing plugs caps and wires does seem like a logical fix.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #6 of 12 Old 08-29-2006, 09:54 AM Thread Starter
crcsjeep
How did you set up a 2 coil setup?
I did replace all wires, cap, rotor, plugs. I believe next shot will be new battery termanals, maybe grounding problem is there. I have already relocated coil away from the original mounting (by exhaust manifold, talk about hot when your on the side of the road w/the stubby and wrench trying to change out the spare you have taken to keeping in the back).
Thanks for all the help!
crcsjeep is offline
post #7 of 12 Old 08-29-2006, 10:05 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I went through several in the first five years of ownership.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 12 Old 08-29-2006, 10:13 AM
Bloodbath
Bloodbath's Avatar
How about finding the ground on the coil and splice into it and temporarily regrounding it somewhere else? If it stops burning up, it's a grounding problem.
-Bill
1998 Red Grand Cherokee Laredo
6" Lift - 32 x 11.5 BFG MT's - K&N FIPK - MSD Ignition with Magnecore wires - JKS Control Arms, Trackbars and QD's - Addco Front Swaybar - Intake Swap - U-turn Steering Conversion
Bloodbath is offline
post #9 of 12 Old 08-29-2006, 10:19 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
I think he meant he just left the origional in place, and just zip-tied the new one near it.
This past year my coil went out. Replaced and so far so good.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #10 of 12 Old 08-29-2006, 04:41 PM
driabyor
driabyor's Avatar
1994 ZJ
thats right.... its just zip tied to old coil.... i didn't change the wiring or anything...
it just runs on the one coil..
and if it ever decides to fail again. It will take me longer to take the part out of the box , than removing the coil..
5.2 liter 242 :)
driabyor is offline
post #11 of 12 Old 08-30-2006, 04:33 PM
Double E
Double E's Avatar
I like that.... I also wonder if an ohm meter would tell him if there's a big diff in resistance from the current ground to a temporary one just to confirm the fix ot find a possible cause...
Double E is offline
post #12 of 12 Old 08-30-2006, 05:13 PM
Swamp Boy
Swamp Boy's Avatar
Jegs actually sells a kit to run 2 coils.. Just throw the switch and it switches from one coil to the other...
I had a simular problem running accell coils.. They suck .. I run an MSD coil now and it is tough..
Just another soccer moms Grocery getter....
Swamp Boy is offline
HELP! Ignition/Coil Capacitor loofashay ZJ Grand Cherokee Forum 0 07-13-2009 10:17 PM
Coil ignition L6 & V8 Ramon2 ZJ Grand Cherokee Forum 1 03-13-2009 03:24 AM
Accel Ignition coil (have one?) easternkidd ZJ Grand Cherokee Forum 0 03-03-2009 09:43 PM
Ignition Coil Question pemberto ZJ Grand Cherokee Forum 5 05-11-2007 10:33 PM
ENGINE COIL FAILURE 4.0 ZJ Adjone ZJ Grand Cherokee Forum 0 07-20-2001 02:30 AM
