If you've replaced your PCM for stalling... - Page 2 - JeepForum.com
View Poll Results: The PCM is for whaich engine?
4.0 75 83.33%
5.2 13 14.44%
5.9 2 2.22%
Voters: 90. You may not vote on this poll
post #16 of 45 Old 03-04-2012, 10:43 AM
Uniblurb
Uniblurb's Avatar
96 Laredo 4WD 4.0: replaced 12/2010 with re-mfg PCM at about 189,000 miles. Stopped the stalling/engine cut-out problems.
Lasted about a year and same problems resurfaced. Just cleaned all engine grounds, ground on body next to battery, and wire-tied PCM connectors tight. Solved the problems and only time will tell if permanent fix.
Threw my 4.0 vote in a few days ago.
Uniblurb is offline
post #17 of 45 Old 03-08-2012, 08:57 AM
andrew520
Autozone Cardone PCM no issues yet
1996 ZJ 4.0L / NP242 / 2" BB / 30x9.5 BFG
andrew520 is offline
post #18 of 45 Old 03-30-2012, 07:41 PM Thread Starter
ZeeJay1997
for the weekend
ZeeJay1997 is offline
post #19 of 45 Old 10-30-2012, 09:50 PM Thread Starter
ZeeJay1997
Just for an update, I spoke with a former quality engineer at the Chrysler electronics plant in Huntsville AL where the ZJ electronics were assembled. They had two vendors for the PCM mother boards, Motorola and some outfit from Texas.
He told some stories of process audits he had performed and quality problem on the production lines during the manufacturing of the PCM, ABS modules, VICs, and BCMs. No wonder our jeeps want to die after 15 years
post #20 of 45 Old 10-30-2012, 10:28 PM
airwolf9090
Still factory in my 96 5.2L tho i do have a stall every now and then didn't have none during the summer but as soon as the cold hit it has stalled atleast once every time i drove it the past 2 weeks 99% of the time right after i started to back up.. And my Voltage reg won't put out more than 12.5V last checked afew months ago.
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #21 of 45 Old 10-31-2012, 04:57 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Tell the tale Zee,what did he say?
Originally Posted by HighLonesome
coralman is offline
post #22 of 45 Old 10-31-2012, 09:14 AM
andrew520
96 4.0L. First Cardone Replacement lasted 8 months and started giving me problems. Exchanged under warranty and this one is giving me same problems after 1 month. I wonder if when Cardone gets these exchanges if they don't just plug it in and if it passes a quick test they re-flash it and resell it without even opening it up.
post #23 of 45 Old 10-31-2012, 07:04 PM Thread Starter
ZeeJay1997
Get some Koolaid to go with the popcorn and I'll tell you a story
As you probably know Chrysler had vendors for all the bit and pieces to include circuit boards. They had problems with their suppliers sending them nonconforming material (AKA bad parts). The bulk of the conversation was about Chrysler's plight to bring their suppliers up to speed so that the parts they sent them would work when assembled into the modules at the plant.
One particular problem was that they had to rework a lot of the ABS boards because the supplier soldering process wasn't up to spec and they were leaving voids in the thru board connections.... imagine that
I let him know that despite their effort to turn out a reliable product, the effort wasn't 100% successful and told him about all the problems with the ABS board that are cropping up now, as well as the PCM problems.
At that time, the EPA was requiring manufactures to lower the lead content in solder and reliable processes were not well implemented among their suppliers. I can only guess that the same process/material problem affected the other sub assemblies as well. We know the VIC is involved. I didn't get all the details I wanted. I didn't get into which PCMs came from where and the manufacturing quality problems. That's for another day, we both were at work at the time and had to move on.
If i can glean any other pertinent info I'll post it up.
post #24 of 45 Old 10-31-2012, 08:23 PM
coralman
coralman's Avatar
I'll stayed tuned, to "as the solder burns" lol. You just have to wonder if the epa actually had "solder batch testers".
coralman is offline
post #25 of 45 Old 09-24-2013, 07:08 PM Thread Starter
ZeeJay1997
Seems like there have been a rash of bad PCMs lately so it's time to bump the poll.
post #26 of 45 Old 09-24-2013, 07:59 PM
zachjf
I fought with a failing PCM on a friends Jeep for awhile using all the fixes on the forums, finally I got tired of screwing with it and found her a used one that works flawlessly without zip ties or soldering the board and it only cost $50
Needs parts?
PM
or
zachjf is offline
post #27 of 45 Old 09-24-2013, 08:07 PM Thread Starter
ZeeJay1997
I put one JY PCM in mine and it lasted 8 months. It's luck of the draw no matter where you get them.
post #28 of 45 Old 02-17-2014, 02:04 PM Thread Starter
ZeeJay1997
The plant where the ZJ electronics were assembled and tested is going to be a Remington arms plant. I hope plant doesn't have bad karma.
post #29 of 45 Old 02-18-2014, 05:32 AM
coralman
coralman's Avatar
The guns will probaly shoot out a flag that says "BOM" instead of BOOM!
coralman is offline
post #30 of 45 Old 02-18-2014, 06:00 AM Thread Starter
ZeeJay1997
LOL. or they will misfire just when you need them most.
check engine light , connector , pcm rebuild , stalls
Replaced CV Axle replaced. Still making noise blacksheepZJ ZJ Grand Cherokee Forum 29 11-24-2012 01:38 PM
Replaced thermostat, now STALLING??? huh? GenesisGirl ZJ Grand Cherokee Forum 22 07-21-2010 02:19 PM
Replaced my VC! EGrier ZJ Grand Cherokee Forum 6 11-02-2005 12:05 PM
Do I need my TC replaced? Scribesoft ZJ Grand Cherokee Forum 8 10-05-2005 07:27 PM
