idles down then quits - JeepForum.com
post #1 of 2 Old 11-06-2006, 02:33 PM Thread Starter
nursematt
I have 99 wj limited. Starts well and runs well while sitting. When driving or increasing rpm's while driving or sitting the wj idles down and shuts off. I think the fuel pump is working ok, but just in case I changed the fuel filter. Still has this problem after changing the fuel filter. Starts fine, but when pressing down accelerator the engine reves up and then idels down to 0. Any help would be greatly appreciated.
nursematt is offline
post #2 of 2 Old 11-07-2006, 11:41 AM
textrailkiller
I have the same problem on my 93 zj 4.0l......im left with the map sensor.....i havent changed it yet.......but i chaged the fuel filter, plugs, wires , dist, tps, and IAC, and still no luck.....finaly got a map sensor code.......try the on off on off on amd see if it give you any codes
textrailkiller is offline
4.0 GC Quits running simsup ZJ Grand Cherokee Forum 7 10-23-2014 09:40 PM
'99 4.0l, Turn Right, Engine Quits, Help ?! JIM ROLAND ZJ Grand Cherokee Forum 3 04-07-2007 09:11 PM
speedo jumping and sometimes quits? 02Lightning ZJ Grand Cherokee Forum 4 12-08-2005 10:47 AM
engine quits :mad: zbigniew ZJ Grand Cherokee Forum 2 07-09-2005 02:41 PM
Starts & Quits--Sometimes? Herb Jenssen ZJ Grand Cherokee Forum 2 12-01-2002 02:56 PM
