idler pulley is shot. - JeepForum.com
post #1 of 28 Old 06-29-2008, 07:31 PM Thread Starter
sandman
idler pulley is shot. (edit) pics added
ok, im not sure if its even called an idler pulley but on the 4.0 its the pulley by the alternator. is that what i call it? well anyways, i went up to the mountains yesterday to camp and fish, it was kind of squeaking on the way up but today on the way home it was making all sorts of racket. so i just crossed my fingers and hoped i would get home. a block from my friends house it made a good pop and then the belt started squealing, i limped to his house and parked it. its gonna be an easy fix. but heres my question, have any of you guys ever had to replace it? and if so did it go out real quick like mine did? and what do you call it, an idler pulley?
1993 Jeep ZJ. 4.0
sandman is offline
post #2 of 28 Old 06-29-2008, 07:42 PM
BLACKzj52
yeah its called and idler pulley.
i thought mine was going out once cuz my belt was squeaking (then i thought it was the ps pump and pulley, just turned out to be the belt
so i replaced it but the squeaking didnt stop.. i basically wasted $35 lol
BLACKzj52 is offline
post #3 of 28 Old 06-29-2008, 09:48 PM
elmer_fud
mine didn't completly go out, but it was squeaking. I called it an ideler pulley, and the places knew what i was talking about, but it took 4 differn't palces to find it.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 28 Old 06-29-2008, 10:15 PM
JCZJ
I've had to replace mine...the bearing basically self destructed and I had to drive ~10 miles to get home, it just made a horrible sound.
As for the replacement, the bolt is really hard to get to...and I'd suggest taking off the fan guard/shroud (says caution fan on it). It's even harder to get to from the back...just takes some elbow grease and some patience.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline
post #5 of 28 Old 06-30-2008, 05:53 AM
Turbonut
Chances are it's been making a slight sound at various times for quite a while, e.g. on cold start. When the sound is first heard, it's a warning, buy a new pulley(s) to avoid a major problem down the road.
Turbonut is offline
post #6 of 28 Old 06-30-2008, 05:03 PM Thread Starter
sandman
well it was easy, did it in my friends apartment parking lot.
messed up pulley.
tools used, and whats left of the bearing=nothing.
slight bit of damage to mounting post
bearing spacer old one on the bottom had the inner race stuck to it. new one is quite a bit smaller but it works.
and done
1993 Jeep ZJ. 4.0
sandman is offline
post #7 of 28 Old 06-30-2008, 06:56 PM
jeepheller98
i bought a new idler puller but it got all full of dirt and stuff from wheeling right away and was making noise, and i didnt want to replace it because it was new. so i took it apart cleaned it with some parts cleaner and pushed some bearing grease in it and it hasnt made noise in 6 months
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #8 of 28 Old 06-30-2008, 07:09 PM Thread Starter
sandman
thats funny i did that to this one when i did my water pump around 8 months ago. this is why i think it failed.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 28 Old 07-12-2008, 04:18 PM
lma1973
I just followed this procedure and everything went great until i started her up and within 10 seconds, the belt has slipped off and the new idler pulley is bent and shot already. UGH!!!
2005 Jeep GCL Hemi
Gibson 3" catback exhaust
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #10 of 28 Old 07-16-2009, 11:52 PM
g2mike
mine just went today. when i pulled over and popped the hood it was shooting sparks! haha
g2mike is offline
post #11 of 28 Old 07-17-2009, 01:18 AM
StellaTheZJ
You don't need to buy a pulley to fix these. The idlers use a very common bearing, which can be pressed out and in easily. Look on the bearing seal and you'll see the bearing is marked with a number . I think it's #6203? This bearing is used in many vehicles (like Mistubishi V6 idlers, GM V6 idler, etc) so it should be available at your parts store, and probably cheaper than a pulley and bearing assembly! I've just done this on 2 ZJs and an XJ.
StellaTheZJ is offline
post #12 of 28 Old 07-17-2009, 02:34 PM
elmer_fud
yeah but for $15 or whatever the pulley costs (somewhere near that) and not having a press it is easier to just get a new assembly
Brian
post #13 of 28 Old 07-17-2009, 03:35 PM
BLACKzj52
mine was 35...
post #14 of 28 Old 07-18-2009, 12:01 AM
StellaTheZJ
The bearing can be changed with a vice and two sockets (or pieces of pipe, or???), although a press makes it easier.
post #15 of 28 Old 07-18-2009, 11:15 AM
dcvance87
My idler pulley went out a couple weeks ago, yesterday my belt tensioner pulley went out, gotta put the new one on today.
06' TJ, 4" Rough Country lift, 2" body lift, 35 BFG all-terrains.
dcvance87 is offline
4.0 ZJ idler pulley help. max_overdrive ZJ Grand Cherokee Forum 5 11-21-2009 08:52 PM
04 6 cyl idler pulley georged ZJ Grand Cherokee Forum 7 06-12-2009 09:46 AM
Idler Pulley rschunk ZJ Grand Cherokee Forum 8 10-03-2005 03:21 PM
5.2 Idler Pulley bnhcooper ZJ Grand Cherokee Forum 6 01-04-2005 09:28 AM
JGC 5.2L idler pulley ely3rd ZJ Grand Cherokee Forum 1 07-09-2003 06:55 PM
