Idle speed control "problem" - JeepForum.com
post #1 of 11 Old 11-05-2008, 05:55 PM Thread Starter
arieson35
2000 ZJ
Hi everyone, I have this IAC problem that i thought problem was solved! I bought this idle air control from some after market parts store (way cheaper than the dealer) But only did the job for less than a week so I took it back and got another one for free, and sure same thing happen again so i decided to go and buy one again, this time from a dealer but then worked only for nearly 2 weeks and i was told by my son it's doing it again. Is there some thing else thats causing this problem? Originaly the problem is... it would not stay running unless you keep your foot on the gas pedal until it warms up. Someone help
arieson35 is offline
post #2 of 11 Old 11-05-2008, 07:13 PM
elmer_fud
check the wires in the connector for the IAC. Maybe one of the wires is loose and wiggles loose after a week. I am assuming you are talking about the IAC (idle air control) controls the idle.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 11 Old 11-05-2008, 07:59 PM
Vestjam
The Throttle Position Sensor (TPS) may actually be the problem.
IF you replace it, get one from the dealer. I tried the consumer (cheap) method and bought one from an autoparts store, only to replace it with a Mopar one 2 months later. No problems since.
Give the throttle body a good cleaning also.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #4 of 11 Old 11-05-2008, 10:09 PM Thread Starter
arieson35
2000 ZJ
yes it is IAC, and i already change the tps as well, throtle is well cleaned but this cold start problem is a big battle for me. wires been wigled a lot before but no difference is noticed. Im starting to think it could be the ECM. PLS. let me know any possible problem.
post #5 of 11 Old 11-05-2008, 10:12 PM
-Joe-
-Joe-'s Avatar
have you tried pulling the check engine codes?
Its free.. do it.. no reason not to.
To display codes cycle the ingition key On-Off-On-Off-On within three seconds. Count the number of flashes, first digit, pause then second digit will be displayed in a series of flashes. (2 flashes, pause, 1 flash = 21)
In your case the digital odometer shows the codes i think..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #6 of 11 Old 11-05-2008, 10:28 PM Thread Starter
arieson35
2000 ZJ
there is no check engine light but scanned it anyway, no codes. once i disconnect the iac harness and start then check engine comes on.
post #7 of 11 Old 11-06-2008, 08:44 AM
pjkatz04
i have a left-field theory...has the car battery died lately?
2002 4.7, Selec-Trac, K&N FIPK II, JetChip Stage 1.
pjkatz04 is offline
post #8 of 11 Old 11-06-2008, 09:45 AM
Double E
Double E's Avatar
Plugs in good shape? I'm wondering what else may change dramatically like that with cold starts and its properties changing once warm...
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #9 of 11 Old 11-06-2008, 05:44 PM Thread Starter
arieson35
2000 ZJ
Plug is good and Yes battery went dead once but replaced and charge been good. this happened during the time of changing IAC to One another.
post #10 of 11 Old 11-06-2008, 05:55 PM
-Joe-
-Joe-'s Avatar
Check the coolant temp sender.. If its an I6 its the one at the front of the engine..
and what leads you to believe its the iac? Aftermarket ones are fine.. I have both non-mopar IAC and TPS and no problems..
Provided you arent trying to adjust the IAC before installing it. (no need whatsoever to move the pintle) You need to start testing some things before replacing parts. IF you have a multimeter you should start checking some things.
- Joe -
-Joe- is offline
post #11 of 11 Old 11-06-2008, 07:10 PM
pjkatz04
Ok well the only reason i asked was because I had a ZJ and i remember that if the battery died it tripped some funky anit-theft thing where if you reconnected the battery and started the car it would automatically stall out. had to get around it by locking the car with the alarm clicker and unlocking the drivers door with the key, holding it in the unlock position for like 20 seconds. that assured the car that you were in fact the owner. then it would stay running on startup.
pjkatz04 is offline
"Idle surge" only when in gear steveheibel ZJ Grand Cherokee Forum 3 02-15-2010 05:13 PM
WJ Front axle/brakes "Binding" at slow speed jasn1981 ZJ Grand Cherokee Forum 0 06-29-2009 09:54 PM
Transmission "sticking" and very eratic idle BlkcobaltSS ZJ Grand Cherokee Forum 0 07-21-2008 11:00 AM
Lower the Cruise "Set" Speed? adgjqetuo ZJ Grand Cherokee Forum 3 03-05-2007 01:04 PM
WJ-Cruise control not "Setting". Any advice? CuStOm ZJ Grand Cherokee Forum 12 07-26-2004 05:28 PM
