Idle problem on cold start - JeepForum.com
post #1 of 3 Old 09-10-2003, 11:55 AM Thread Starter
javapro
Hi,
I have a 98 ZJ 4.0 inline 6. This morning, on a cold start it would not idle by itself unless I kept my foot on the gas. This happened once before, about two weeks ago, but between then and now it's been fine. I'm not certain, but I think the problem went away if I kept my foot on the gas, then moved the transmission to "D" - it's almost as if the engine wont idle in "P" or "N" by itself. This might have just been coincidence as the car may have warmed up or something.
Any ideas ?
javapro is offline
post #2 of 3 Old 09-10-2003, 12:00 PM
ALS59LTD
ALS59LTD's Avatar
try testing/replacing your IAC motor (idle air control) not sure where it is on the I6, should be near the throtle body.
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
post #3 of 3 Old 09-10-2003, 12:25 PM
Jillie
Jillie's Avatar
i had the same problem last year...it only got worse....it stopped after i replaced the battery.....
not sure if that could be your problem but it was mine.....i was late to work many times because of that.....then one day it just died in the middle of an intersection after comming home from checking out a band at a bar. my time in my center console kept resetting also......(sign my battery was low)
97 I6 ZJ
K&N FIPK
Flowmaster muffler
Jillie is offline
Erratic idle at cold weather start-up. smoulding ZJ Grand Cherokee Forum 3 11-26-2009 09:27 AM
High rpm idle on cold start. Frangeron ZJ Grand Cherokee Forum 3 07-23-2008 04:54 AM
High idle at Cold start? hinchcliffe ZJ Grand Cherokee Forum 5 11-02-2006 08:04 AM
Surging idle at cold start mtcox ZJ Grand Cherokee Forum 5 06-05-2006 07:25 PM
Rough idle at cold start --- 01' Grand with I-6 VA_Jeepster WJ Grand Cherokee Forum 7 09-02-2003 05:07 PM
