Idle Issue at a stop - JeepForum.com
post #1 of 12 Old 01-25-2013, 08:46 AM Thread Starter
SAbbott812
Hi everyone, it's me again.
It is not a huge issue as of yet but, I would like to keep it from becomming an issue. MY GC will run great when cold but, occasionally when warm and you stop at a light after driving a bit there will be very slight fluctuation in the RPM's and the truck will shake a bit. Sometimes it does it once, sometimes it does it over and over again. I thought it was the IAC so I cleaned it and it seemed to help but, then it came back. (I did this over and over for a bit.) Finally I replaced the IAC at NAPA. The problem has not gone away and it is not really getting worse. I would just like to stop it. Any suggestions? Could it be the TPS? Thanks for your help!!!
Sandy
Pertinent info:
98 Jeep Grand Cherokee Laredo L6
189,000 miles (approx)
top end rebuild (with engine mounts) in 2007
new springs, tranny mount, and bushings 2012
SAbbott812 is offline
post #2 of 12 Old 01-25-2013, 08:52 AM
FAlfani81
Torque Converter?
FAlfani81 is offline
post #3 of 12 Old 01-25-2013, 09:14 AM
bigbill888
Heater control in defrost position when this is happening?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #4 of 12 Old 01-25-2013, 09:23 AM Thread Starter
SAbbott812
@bigbill888 I don't believe that it is but, I will keep an eye on it and let you know.
@FAlfan81 Will the TC effect the idle at a stop? Sorry to ask that question but, I really do not know.
post #5 of 12 Old 01-25-2013, 09:25 AM
FAlfani81
It could if its locking up. Kinda like driving a 5spd and not pushing the clutch all the way and leaving it in gear when you stop.
post #6 of 12 Old 01-25-2013, 10:31 AM Thread Starter
SAbbott812
Could it be an O2 sensor?
post #7 of 12 Old 01-25-2013, 10:40 AM
PolkaPower
Sounds like it might be a sensor since it only does it after warm up.
PolkaPower is offline
post #8 of 12 Old 01-25-2013, 11:27 AM
Donnyd21
Yes it could be a O2 sensor.
Donnyd21 is offline
post #9 of 12 Old 01-28-2013, 09:59 AM Thread Starter
SAbbott812
Ok, I drove it around again this weekend. It is not affected if the radio or the heater / defrost is on. The headlights also do not make a difference. (Not sure that is important, just an observation). I am also wondering if there could be a short somewhere in the wiring on the IAC. Frustrated as I am not getting a check engine light or anything. I should have it read for codes though.
BTW, how many O2 sensors are there? Anyone know which one might be a culprit?
post #10 of 12 Old 01-28-2013, 11:02 AM
dougmorgan99
Your 98 should be OBDII so it should have 2.
dougmorgan99 is offline
post #11 of 12 Old 01-28-2013, 01:48 PM Thread Starter
SAbbott812
Is there a way to check the O2 sensor or will it throw a code?
post #12 of 12 Old 02-10-2013, 08:01 AM Thread Starter
SAbbott812
OK new update. I was driving down the highway yesterday and for some reason the tach jumped about 500-700 rpm but then returned to normal and did not do it again. The idle is still rough. I have not replaced anything besides the IAC that I purchased at NAPA. Any further thoughts?
