at idle has a weird vibration - Page 2 - JeepForum.com
post #16 of 25 Old 02-21-2012, 04:55 PM
hdrocknroll
Oh ya forgot, Anchor Engine Mounts from Advance,Part No. 2794,Part No. 2793, $41.20 for both with discount code.Can also be had, at Rock Auto 13 bucks a piece,Trans mount ANCHOR Part # 2864 16 bucks plus shipping.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #17 of 25 Old 02-21-2012, 07:10 PM
ZJPRKID
If you don replace all mounts at once the new ones will deteriorate in a cupel of weeks to were it would be recommended to replace them again
ZJPRKID is offline
post #18 of 25 Old 02-21-2012, 07:12 PM
shad366
It is the motor or transmission mounts. Mine does the same thing.
2002 Jeep Grand Cherokee 4.7 V8 WJ
shad366 is offline
post #19 of 25 Old 02-21-2012, 07:13 PM
hdrocknroll
Oh Ya !! Trans mount will be done next week, had to order it.
post #20 of 25 Old 02-21-2012, 07:17 PM
hdrocknroll
Both,will cause the vibes,other people on here fixed problem, same way.
post #21 of 25 Old 02-22-2012, 12:32 AM
hdrocknroll
Here is better pic ,what new one looks like,all rubber intact,no holes,no tears,cant see any light through it.
post #22 of 25 Old 04-26-2012, 10:45 AM
soulat0
1994 ZJ
I have the vibration issue too, and it only got worse after adding the lift. I noticed when I put the transfer case in neutral, the vibration seem to go away. Do you think this could still be an issue with the mounts, or an issue with the t-case?
soulat0 is offline
post #23 of 25 Old 04-26-2012, 11:06 AM
hdrocknroll
First thing would be to check the mounts.
It could be the mounts, cuz when U put the TC in neutral ,I don't think there would be a load in the engine.
Maybe some one else will chime in with more detail
post #24 of 25 Old 04-26-2012, 11:43 AM
dean477
do you have to have an engine crane to change the mounts? Or how do you go about supporting the engine while changing them?
dean477 is offline
post #25 of 25 Old 04-26-2012, 11:53 AM
hdrocknroll
Jack the engine, With a 2 by, board across the oil pan.I used short pc. of 2X8
idle issue , idle problems , idles rough , vibrating , vibration
Weird vibration 98ZJDan ZJ Grand Cherokee Forum 6 03-19-2010 05:48 PM
Weird vibration at low speed/idle befumo ZJ Grand Cherokee Forum 0 06-03-2009 12:56 AM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
weird vibration jeep1987 ZJ Grand Cherokee Forum 6 12-05-2006 08:22 AM
Weird Vibration :S ??? jeepunlimited ZJ Grand Cherokee Forum 2 11-24-2006 11:04 AM
