at idle has a weird vibration - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > at idle has a weird vibration
Poison Spyder from CCOR!Warn, Smitybilt, Engo, Rugged Ridge Winches at CCORRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 02-16-2012, 06:26 AM   #1
edcalli
1994 ZJ
The vibration can be felt throughout the hole vehicle it kind of seems like a low idle because if u press the gas a little it goes away. The idle is btw 500 and 750rpm.it doesnt do it at cold start up when rpms are higher
edcalli is offline   Reply With Quote
Unread 02-16-2012, 07:00 AM   #2
squazz
if it aint missing I would start by checking the motor mounts and transmission mount as well
squazz is offline   Reply With Quote
Unread 02-16-2012, 07:25 AM   #3
jnowak
Mine does the same. About 1k smooths right up. But at idle all the windows and plastic shake
jnowak is offline   Reply With Quote
Unread 02-16-2012, 09:17 AM   #4
speedbucket
Clean your throttle body and IAC
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj,4.5" ...coming- boat sides, rear stretch, tringulated 8.8, streched front HP30, bead locked 35s.....
speedbucket is offline   Reply With Quote
Unread 02-16-2012, 10:52 AM   #5
edcalli
1994 ZJ
i'll try cleaning throttle body and iac thanks 4 advice.
Unread 02-16-2012, 04:03 PM   #6
hdrocknroll
Mine to
So !! how do you go about checking the motor mounts and transmission mount.
already cleaned throttle body and IAC, new crank sens, o2 sens,full tune up.
Is the transmission involved in the equation ,when in park ?
Edit: Mostly only doing it in gear.
Only vibration in neutral or park is a little when engine is brought up to 1500 rpm at 2000 it goes away
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
[QUOTE=rooster51;13297693] Whats the worse that can happen? Your jeeps already broke.
[/QUOTE]
hdrocknroll is offline   Reply With Quote
Unread 02-16-2012, 05:47 PM   #7
mikethefisher
mine has the same vibrating syptoms, in drive and park. it vibrates more in drive but when you put it in neutral the vibrating starts.
mikethefisher is offline   Reply With Quote
Unread 02-17-2012, 01:42 PM   #8
hdrocknroll
Any one else ,like to chime in here?
It would be greatly appreciated
[/QUOTE]
Unread 02-17-2012, 04:47 PM   #9
jnowak
I have done all the approiate cleaning and tune ups. I am leaning toward engine mounts only thing i havent check
Unread 02-17-2012, 04:57 PM   #10
4Slow9erHybrid
It's a common complaint for the 4.0L ZJs. There's no definitive solution. Keeping the IAC clean, tune up helps but doesn't get rid of it. I replaced 1 engine mount and the tranny mount with no change. The new Anchor driver's side mount was defective, hence could not change it.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline   Reply With Quote
Unread 02-17-2012, 05:24 PM   #11
cdaniels85
I'm in this boat as well. Misery loves company.
cdaniels85 is offline   Reply With Quote
Unread 02-18-2012, 04:54 AM   #12
hdrocknroll
Could this be something like torque converter, or trans related ?
[/QUOTE]
Unread 02-18-2012, 10:14 AM   #13
cdaniels85
I first thought the same thing, then I had my tranny looked at and was told it is in great working order. I think it's mostly a combination of an inline engine and worn mounts. The mounts don't appear to be shot, but I think it just takes a little wear and the nature of this beast takes over.
Unread 02-18-2012, 03:36 PM   #14
hdrocknroll
Well !! It Doesn't look to hard to replace the three mounts.
Not expensive, I can get all three for 60 bucks.
I will take a look at them, and see what I can see. I don't know what else it could be.
After I replace them ,I will let you all know if it helped or not.
[/QUOTE]
Unread 02-20-2012, 05:37 PM   #15
hdrocknroll
Well, my motor mounts were shot.
Replaced them today and dudes, it's running smooth. Now, only a very very slight vibration but I haven't done the trans mount yet.
The difference is like night and day. I don't know if this is everyone's problem with the shaking, vibrating, but it sure was mine.
The left one that I didn't take a picture of was a little worse than the one in the pic.
If yours are as bad as mine were, all you have to do is reach down there, and and see if you can stick your finger through it, if you can its shot.
You can see the old one is even separated at the bottom.
I put it in the snow so you could see the separation.
The second pic is not very good but the new one is on the left.
[/QUOTE]
idle issue , idle problems , idles rough , vibrating , vibration
