Idle air control valve bad??? 93 grand cherokee limited 5.2l 8cyl - JeepForum.com
post #1 of 7 Old 06-06-2012, 05:54 PM Thread Starter
xv_nj
What would the signs of a bad idle air control valve be?
xv_nj is offline
post #2 of 7 Old 06-06-2012, 06:43 PM
JasonStebbins
Rough idle. High idle. Starting problems. Intermittent stalling problems.
JasonStebbins is offline
post #3 of 7 Old 06-06-2012, 07:01 PM Thread Starter
xv_nj
thanks..im hoping to get to the bottom of this stalling problem. check my other posts if u have the time and u can see what i am going thru. really trying to get this old clunker running good for fishing. body is mint, inside needs new front seats and carpet replaced, other then that the transmission and engine ran great until now. did have a problem with starting and losing battery connection before all this. had to jiggle the negative terminal to get power. replaced terminals/part of wire with splice kit
xv_nj is offline
post #4 of 7 Old 06-06-2012, 07:08 PM
JasonStebbins
Didn't notice the other posts. Give me a quick description of your problem? If you wiggled the negative battery terminal and it fixed the problem, I would buy two new brass battery terminals and cut off a little bit of the wire and use a new chunk for each side.
Also check the ground that goes to the inner fender from the negative terminal.
Without knowing any background, I would guess a bad Crank Position Sensor/Throttle Position Sensor or fuel related issue.
Have you already tried cleaning the IAC?
post #5 of 7 Old 06-06-2012, 09:39 PM Thread Starter
xv_nj
what is the iac and how would i clean it/with what? i purchased 2 of these to replace the terminals (on the positive side i used electrical tape to close off that smaller wire in the center as the positive side only had 2 thick cables)
http://www.autozone.com/autozone/par...7_339808_5977_
inspected the ground on the negative side and it seemed fine.
heres info from a my other post
last week my truck started stalling on me. i would turn the key and it would start but then shut off a second later, then after a few attempts it started but then stalled when i accelerated.
changed a few things since fri - battery terminals (used a splice kit that replaced the terminal & a few inches of wire), pcv valve & grommet, spark plugs & wires, fuel filter, air filter. attempted to change the distributor cap but 1 screw was striped previously so i couldnt do it.
now after all this i attempted to start it and it would keep stalling, then it finally stayed running with the idle halfway to the 1 (not sure if it was always/suppose to be like that) and once again when i accelerate it stalls.
i read somewhere on this forum about listening for a noise in the fuel pump. i turned the key without starting the vehicle and had the door open and i did hear a winding noise.
also i just replaced the throttle position sensor.
xv_nj is offline
post #6 of 7 Old 06-06-2012, 09:48 PM Thread Starter
xv_nj
here are some of my other posts. wondering if something is screwed up from all the times i tried starting my jeep when the negative terminal was bad and it would click when i turned key and lose connection. thats when i had to keep jiggling terminal and try and start again until it did.
http://www.jeepforum.com/forum/f13/9...-8cyl-1377301/
http://www.jeepforum.com/forum/f13/o...-8cyl-1377481/
http://www.jeepforum.com/forum/f13/a...-8cyl-1377488/
xv_nj is offline
post #7 of 7 Old 09-13-2012, 06:04 PM
theopacific1
did you replace the iac? did it help the idle?
theopacific1 is offline
Air not blowing out of all vents - 93 grand cherokee limited 5.2l 8cyl xv_nj ZJ Grand Cherokee Forum 9 06-12-2012 07:04 PM
Tempature gauge problem - 93 grand cherokee limited 5.2l 8cyl xv_nj ZJ Grand Cherokee Forum 2 06-07-2012 03:38 AM
93 grand cherokee limited - questions 5.2l 8cyl xv_nj ZJ Grand Cherokee Forum 7 06-06-2012 05:59 AM
Oil pressure gauge problem - 93 grand cherokee limited 5.3l 8cyl xv_nj ZJ Grand Cherokee Forum 2 06-05-2012 06:46 PM
95 Grand Cherokee Stalling...Idle Air Control Valve G4teamG ZJ Grand Cherokee Forum 2 02-18-2009 02:45 PM
