Idle air control code - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Idle air control code
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread 06-17-2015, 02:48 AM   #1
oneilboy2001
I have a 96 grand Cherokee limited w/5.2L and the check engine light keeps coming on and the code is saying idle air control. We'll I have replaced the idle air control motor/ sensor and the Check engine light still won't go off. I have turned into a big jeep guy since owning this Cherokee so please give me some feed back helping me figure out this problem.
oneilboy2001 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2015, 03:17 AM   #2
PolkaPower
Did you unhook the battery when you replaced the sensor? Try doing that. If that doesn't work, it's possible that the sensor is bad out of the box if you did not use a Mopar sensor.
The parts store sensors are a gamble and a lot are faulty right from the start.
Unhook the battery for a few minutes to clear the code. If it comes back then you'll have to do more trouble shooting. Keep in mind that the computer need a bit of driving time to adjust to the new sensor.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 06-17-2015, 10:50 AM   #3
Oldfrog
Ditto...on all of the above.
Cajun Recipes and Fishing tips
On 7th PCM. Finally got a good one.
Stalling? Work through Zeejay's list
God Bless the Garland, TX Police Dept.
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread 06-25-2015, 01:03 AM   #4
oneilboy2001
Thank you I did that and have drove it about 75 miles now and it hasn't come back on so I think I'm good
