Ideas for securing 4 point harneses - JeepForum.com
post #1 of 13 Old 08-20-2013, 09:36 PM Thread Starter
RagTagSoldier
Ey guys, next spring in taking the jeep to silver lake for some dune jumping but before then I want to get some harnesses installed. Does anyone have any ideas for securing the shoulder straps behind the seats. I have crappy welding experience so welding a cross bar behind the seats at shoulder height is prettying out of the question.... Bolt in options????
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #2 of 13 Old 08-20-2013, 10:19 PM
dnuccio
usually, harnesses are secured to a roll cage. at least thats how all the ones ive seen are.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 13 Old 08-21-2013, 03:28 AM
zachjf
Not to be a d**k but nothing about jumping a unibody rig is a good idea. Being an ex auto body tech and current mechanic I've seen unibodies tweaked and all sorts of other damage from bumping a curb wrong @15mph so jumping a unibody, even a Jeep, is a bad idea!
Needs parts?
PM
or
zachjf is offline
post #4 of 13 Old 08-21-2013, 04:30 AM Thread Starter
RagTagSoldier
Your okay. I am always open to advice. How about just racing at the dunes or climbing them?
post #5 of 13 Old 08-21-2013, 05:50 AM
Technohead
Frame construction is not the issue. There are plenty of unibody rigs catching air. For example the JeepSpeed series. If you are going to be jumping this rig then of course you need a harness but before that you need to invest some serious $$$ in the suspension. And in particular progressive rate bump stops, shocks, and beefed up mounting points. Followed by a cage. And then the harness comes into the picture.
-Eric
Technohead is offline
post #6 of 13 Old 08-21-2013, 07:11 AM
speedbucket
A harness is dumb without a cage......it'll just hold you in place better for getting crushed
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 13 Old 08-21-2013, 11:38 AM Thread Starter
RagTagSoldier
Well I've watched a couple of videos on jeepspeed.... Pretty sure I finally have a definitive goal as to where I want my jeep to end up....
post #8 of 13 Old 08-21-2013, 12:48 PM
kg6mov
Hears the voices
kg6mov's Avatar
Harnesses/racing seats are designed to work together with a roll cage. Stock seats and shoulder belts are designed to buckle so you double over in the event of a roll over. A racing harness without a roll bar is more dangerous than a stock setup.
Get a local shop to put in a roll bar.
kg6mov is offline
post #9 of 13 Old 08-21-2013, 03:30 PM Thread Starter
RagTagSoldier
Of by roll bar you mean the bar behind the seats that the harness straps to. Then yes I am making up the plans to have one put In by my finances dad as he is a master welder. I will then base the rest of my cage around that
post #10 of 13 Old 08-21-2013, 04:32 PM
dnuccio
dont just put in a bar for the harnesses to mount to. that could literally be digging your own grave. put in a full roll rage
R.I.P. Ratmonkey
dnuccio is offline
post #11 of 13 Old 08-21-2013, 06:54 PM Thread Starter
RagTagSoldier
Oh I plan to. My brother has been racing stock car since he was 15 so I know how important saftey is. I have all winter to design it. I am designing it around the existing belt system so you can still use the stock 3 point harness
post #12 of 13 Old 08-21-2013, 08:02 PM
dnuccio
gotcha
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 13 Old 08-21-2013, 08:13 PM Thread Starter
RagTagSoldier
Lol just wanted to see if there were any bolt on options, ( I donor possess the tools nor skill to make one and am not fond of other people touching my rig) the only one I can find is the one from rock hard 4x4 but I don't hear very good things about it lol
