Iceland Flares Question - JeepForum.com
post #1 of 17 Old 07-09-2011, 06:15 PM Thread Starter
Nickell80
1997 XJ Cherokee
I tried searching but couldn't find any kind of answer.
Soo, I'm gonna get my Green ZJ back from my dad and was thinking...
Since it needs paint anyways I want to get Iceland flares and have a shop install since I am scared ****less of body work (not sure why).
How much lift do you guys think I would need to fit 33's? Well probably 285/75r16. I was thinking maybe 2" at most and still have room to flex a little.
And how well do you think that semi tucked 33's would fit and fill the wheel wells? I see the pics of ZJones with the set up and 4.5" (I think) of lift and the tires looked to small, obviously why he put on 35's.
I'm trying to go for as little lift as possible.
Also, for anyone interested, I'm planning on getting the flares and the cladding covered in color match Rhino Lining (Their shop is right next to my work) and then just regular paint like normal everywhere else.
White 97 2 Door 4.0 5 Speed XJ
Nickell80 is offline
post #2 of 17 Old 07-09-2011, 08:35 PM
NapsterZJ
I could have sworn seeing a picture of a euro ZG with BB and 285s with the iceland flares so i know its definitely doable. 3" lift is definitely the ideal lift for flex and iceland flares and 33s
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
post #3 of 17 Old 07-09-2011, 10:36 PM
KingtheZJ
i have them. you can definitely fit 33s on 3". i believe their claim of 35s on 4. see pics in my build thread and photobucket
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 17 Old 07-09-2011, 11:41 PM Thread Starter
Nickell80
1997 XJ Cherokee
Thanks for the input guys.
King, I'll check that out right now.
Did you do the flares yourself or have a shop do them? I really am not a fan of any kind of body work, especially when I heard that welding may (or will) be required.
post #5 of 17 Old 07-09-2011, 11:44 PM
Jones
Consider the following...
Jones's Avatar
You'd have to trim a lot more than what the instructions say. My 35's rub at 5.5" lift when turning on flat pavement.
Jones is offline
post #6 of 17 Old 07-09-2011, 11:47 PM
Jones
Jones's Avatar
Mine was at 5.5" lift with worn out 33's that were pretty close to 31" tall. I think 3-4" lift with 33's would look good though.
Jones is offline
post #7 of 17 Old 07-10-2011, 04:50 PM Thread Starter
Nickell80
1997 XJ Cherokee
Cool, thanks.
post #8 of 17 Old 07-11-2011, 11:04 PM
85IrocZ-28
I would run a three inch lift with 33's, trim underneath, and extend the bumpstops.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #9 of 17 Old 07-12-2011, 12:23 AM Thread Starter
Nickell80
1997 XJ Cherokee
That's what I'm thinking.
I'm a little worried about the cost for a body shop to do the work though.
post #10 of 17 Old 07-12-2011, 11:04 AM
85IrocZ-28
You should at least do the fronts yourself...they are easy. Just drill holes, bolt it on, draw a line, remove the flare, cut the fender, touch up the bare metal with spray paint, re-install the flare.
The rear requires more work, but the fronts are easy.
post #11 of 17 Old 07-12-2011, 04:59 PM Thread Starter
Nickell80
1997 XJ Cherokee
Awesome, that's good to know. I guess I will just figure it out once I get them though and see what all I can actually do myself.
I don't know how true it is but I thought I had heard it would be like $1100 for a shop to do the work. That's a bit more than I want to pay. Haha
post #12 of 17 Old 07-12-2011, 05:10 PM
JeepStangGuy
I have 33 MTRs on a budget boost with just a little bit of rubbing that should be fixed once i get different bump stops
JeepStangGuy is offline
post #13 of 17 Old 07-12-2011, 05:20 PM
85IrocZ-28
You could also likely install the door half of the rears on your own. It was easy on the WJ, not sure if the ZJ is different. After you have done that much work, you can decide if you want to try and do the rear half of the rear flares, or if you want a shop to do it.
post #14 of 17 Old 07-12-2011, 07:03 PM Thread Starter
Nickell80
1997 XJ Cherokee
Do you have any pics?
I would just do a BB but my springs are soo worn out that I might as well just get new ones. And I'm pretty sure I still have the factory 17y/o 150k mile shocks
post #15 of 17 Old 07-12-2011, 07:56 PM
JeepStangGuy
here you go, eventually I am going to go with a long arm setup but right now I am putting the money towards lockers and armor
Iceland Flares...size Cutch ZJ Grand Cherokee Forum 1 11-16-2009 09:22 PM
Iceland Fender Flares and Bumper ryanwj09 ZJ Grand Cherokee Forum 17 10-17-2009 11:50 PM
WJ Iceland Fender Flares Pics now up MACHJGC ZJ Grand Cherokee Forum 2 10-22-2008 06:18 PM
berzerk / iceland offroad fender flares Derek33 ZJ Grand Cherokee Forum 11 05-29-2007 11:53 AM
Off-Roading in Iceland jeepejeep ZJ Grand Cherokee Forum 31 02-01-2006 11:04 PM
