IAC issues - JeepForum.com
post #1 of 7 Old 01-12-2014, 02:14 PM Thread Starter
alyman85
1985 FSJ Wagoneer
IAC issues
I have a 94 4.0, and it has been idleing rough. I replaced the O2 sensor, and replaced the IAC yesterday. The idle shoots to 2200 RPM and will not come back down. I unplugged the battery to reset the computer, and the idle is a little lower, but seems to still climb. When I unplugged the IAC and started it, the idle again rose. I'm guessing the issue is with the IAC but I'm not sure how to fix it. Could it be a bad IAC?
alyman85 is offline
post #2 of 7 Old 01-12-2014, 03:47 PM
Oldfrog
2007 WK
I seem to remember an aftermarket IAC that was supposed to do that until the vehicle reached 40 mph or so.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 7 Old 01-12-2014, 07:22 PM
ZeeJay1997
did you clean the chamber while the iac was out?
ZeeJay1997 is offline
post #4 of 7 Old 01-12-2014, 09:20 PM
JasonStebbins
Did you use an NGK/Mopar oxygen sensor? Just went through something very similar with my wifes Alero. Tried a Denso and it made it worse, AcDelco sensor solved the problem (OEM for General Motors)
As ZeeJay said, clean the chamber the IAC mounts into and clean the throttle body as well.
Poop
JasonStebbins is offline
post #5 of 7 Old 01-13-2014, 09:19 PM
dougmorgan99
Cleaned and then replaced my IAC, O2 sensors and TPS trying to track mine down. Finally found it to be my MAP Sensor... Ah well!
dougmorgan99 is offline
post #6 of 7 Old 01-14-2014, 12:30 PM
johns1mj
I had a bad connection at the computer. The IAC would test good. The wires would test fine. I had to reset the pin in the connector at the computer.
johns1mj is offline
post #7 of 7 Old 01-16-2014, 10:45 AM Thread Starter
alyman85
1985 FSJ Wagoneer
So by resetting the computer, driving a little bit, and pausing with the ignition on before starting I got the idle to come down to 900-1000.
Except for when it is cold starting. It won't go at all, I have to give it gas. Once it warms up the idle is decent. Never had problems starting with the old IAC, so I'm guessing I have a bad one? Should I replace the TPS too? And if I clean the throttle body does it have to be re-pressurized?
alyman85 is offline
