01-20-2005, 08:31 PM
#1
What happens if you put a 160 degree thermostat in a 4 Liter?
[COLOR=DimGray]99 Laredo
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
Custom Fiberglass Box
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
Dunlop 265/75/16 mud rovers
[/COLOR]
01-20-2005, 09:17 PM
#2
Good question.
With a stock radiator, 180 degree thermostat, high flow water pump and a slightly higher compression ratio my engine temp never reaches 210. Not even during the summer with the A/C on. My engine temp comes up quickly but never gets higher than ~200. I've noticed this winter that my heater gets plenty warm to keep the windows clear but the air is certainly not hot.
I guess that doesn't really answer your question though.
- Brian
Note: Edited to correct the temps.
For some reason, being a member of the CharGold Jeep Club just isn't as cool... Member #1
01-21-2005, 07:45 AM
#3
Yeah it does thanks. Everytime they tell you to replace the stat they always say use a 195 like the stock one and I didn't knwo why. Thanks.
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
[/COLOR]
01-21-2005, 07:56 AM
#4
Former Mod
I also put a 180 T Stat in a few weeks ago so that I could install a Jet Stage2 chip. Everthing's working fine, plenty of heat, no detonation.
Not sure 'bout a 160 though - why a 160?
Curious
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
01-21-2005, 08:11 AM
#5
When an outcome or result is an unknown, changing a variable more than 10 % is considered drastic. The first thing that comes to mind is, incomplete combustion and hence producing more emissions. I know there is a coolant temperature input to the PCM, but I do not know how the PCM will handle such a low input. One possibility is that the PCM could stay in Closed Mode in which the PCM uses stored input valves instead of real voltage inputs. I am no expert in this area so don’t believe I word I say
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
01-21-2005, 12:43 PM
#6
Way over my head, but if I understood that right, the computer won't turn on correctly or at all until it see's the right temp, that I believe and have seen first hand.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
[B]Black Jeep Club Member Ver. 2 #51[/B]
01-21-2005, 04:53 PM
#7
I put a 160 in my 95 once. It was fine over the summer, but once winter hit I was quite cold until I got a 195 in there. I think it ran better with the 195 anyway, my advice is to stick with the OE, or if your dead set on going lower a 180, but not 160.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
01-22-2005, 07:42 AM
#8
I had a 180 in my older 4.0 and it was cold in the winter, I sold that Jeep, and when I will have to replace my T-stat on my current GC, I will not go lower than 195
Cassius
[COLOR=Silver]Platinum 97 GC LTD[/COLOR]
[COLOR=White]2" BB, Edelbrock Shocks, 31X10.5 A/T MT's on Stock Rims, Bump Extensions, Custom Skid Plates, De-pinstripped, De-badged, 5% tint ALL the way around, Yellow top battery, Grounding Kit, 200 Amp Alternator, (6) 10in JL Audio WO's, (2) JL Audio Slash 1000/1 Amps, Alpine IVA-D300 Headunit, MB Quart mids and highs all the way around, and the volume always at 100[/COLOR]
[COLOR=DarkGreen]JOIN [URL=http://www.norml.org/index.cfm]NORML[/URL] TODAY - FIGHTING TO LEGALIZE MARIJUANA FOR RESPONSIBLE USERS[/COLOR]
01-22-2005, 09:10 AM
#9
A 160 will cause the pcm to stay in closed loop. Which is the warm up mode. It will inject more fuel unnecessarily causing crappy gas milage, carbon build up, and crappy emissions. I have seen some cases where it has ruined O2 sensors and fouling plugs. You might be able to get away with it if you don't have winters, but if you get any cold weather then I wouldn't do it. I'm not really a big fan of the 180's either, but that's just me. I'm on my 4th 4.0 Jeep and have run 195's with all of them and rarely see a temp above 210. Most times it hovers at just below around the 195-200 mark.
Some people thing the 160 stats are the solution to an overheating problem and that's not the case either.
Oh, anyone have any info on MotoRad thermostats?? They are supposed to have a safety feature where when they fail, they fail in the open position???? Most fail in the closed position...
Good Luck
Doug
01-22-2005, 10:36 AM
#10
The amount of electronic spark advance provided by the PCM is determined by five input factors: engine coolant temperature, engine rpm, intake manifold temperature, manifold absolute pressure, and throttle position.
With a cooler thermostat than required by the PCM (be it 180* or 160*), the engine timing will be altered. So fuel will be wasted (running rich), engine timing will be off (possible detonation issues), and emissions levels will increase (possible failure of O2 sensors, catalytic converter poisoning).
HTH
Warren
Black 1996 5.2L ZJ Limited
01-22-2005, 02:06 PM
#11
Alright thanks a lot everybody. I almost made a costly mistake
I6 4.0L 42RE/NP242
Clarion Head
Visonik 12" Sub
MA Audio M1889i Amp
Magnaflow Exhaust
Rusty's 2" BB
[/COLOR]
02-20-2005, 01:58 PM
#12
210 degree operating temp
Latey I have noticed that my Jeep has been hitting the 210 temp mark. I believe it used to get around 200 tops. It never gets over 210. Although it is winter and I dont want o have probs this summer. It is a 4.0. Should I just try to change the stat and see what happens?
02-20-2005, 04:17 PM
#13
That's the first thing I would start with. I would also drain out as much coolant as you can and add fresh. I was suprised on my 01' at how nasty the coolant looked.
When I just did mine I used the "Motorad" thermostat. It is the safety one that fails open if it should happen to fail. I got it at the zone for about $10. So far things seem good.
Good Luck
Doug
