I want 17" on my zj - JeepForum.com
post #1 of 17 Old 02-05-2013, 06:29 PM Thread Starter
plntman
I want 17" on my zj
I was trying to find 17" rims at a junk yard that will work on my 98 zj. I dont want to use spacers, I am replacing my 2010 rubi tires with 35's and want to use the rubi tires on my zj. If not available what do the vendors have to offer?
plntman is offline
post #2 of 17 Old 02-05-2013, 06:34 PM
Freestyle713
1994 ZJ
So let me get this straight. You have 2 jeeps, a zj and a jk. You are getting new wheels and tires for the jk and want to use the jk tires on your zj, and can't run the jk wheels because it would require running spacers, so you are looking for 17's with a 5x4.5 bolt pattern. Correct?
What do you have against spacers? They are perfectly safe when installed correctly. IMO that would be your best option, because you already have the jk tires mounted and balanced on perfectly good wheels.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #3 of 17 Old 02-05-2013, 06:57 PM Thread Starter
plntman
just getting new tires on the JK I am getting Treadwrights https://www.treadwright.com/p-118-31...m-t-b2b-d.aspx and they can be used on stock rims cause they are not as wide as a normal 35"
plntman is offline
post #4 of 17 Old 02-05-2013, 09:20 PM
Bear304inc
To put 17" jk wheels on a zj youll need a set of adapters going from hub side( 5x4.5) to wheel side ( 5x5) bolt patterns.
Bear304inc is offline
post #5 of 17 Old 02-06-2013, 01:57 AM
kg6mov
Hears the voices
kg6mov's Avatar
I don't think you'll find anything at a junkyard but you could grab some cragar soft 8's or d windows: http://www.summitracing.com/search/b...ew=ProductName
kg6mov is offline
post #6 of 17 Old 02-06-2013, 06:21 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Nothing with a low enough back space to allow much taller tires.
Buy aftermarket, or sell the jk tires and but something for the size wheels you already have.
ratmonkey is offline
post #7 of 17 Old 02-06-2013, 07:32 AM Thread Starter
plntman
if I could not find at a JY was thinking of these Level 8 wheels.
http://www.discounttiredirect.com/di...r=1&wd=17&rw=9
plntman is offline
post #8 of 17 Old 02-06-2013, 10:32 AM
MilanJeep
MilanJeep's Avatar
TJ rubicon wheels
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #9 of 17 Old 02-06-2013, 11:07 AM
CatSplat
1994 ZJ
Originally Posted by MilanJeep View Post
TJ rubicon wheels
TJ Moab (Rubicon) wheels are 16", not 17".
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #10 of 17 Old 09-28-2013, 10:31 PM
CareyKimber
JKs are 17 but 5x5 bolt pattern so you'll need spacers but they look good.
Kimber ZJ Build
http://www.jeepforum.com/forum/f22/kimber-zj-build-1626817/
CareyKimber is offline
post #11 of 17 Old 09-29-2013, 01:09 AM
XJ90
have you looked into some charger wheels? i have 18" charger wheels on my zj, but there are 17" wheels as well.
XJ90 is offline
post #12 of 17 Old 09-29-2013, 01:27 AM
Bear304inc
Kimber ZJ Build
How much lift are you running? ZJ looks sweet...
post #13 of 17 Old 09-29-2013, 04:03 AM
CareyKimber
OME HD springs and Bilstiens from Kolak
1.5 polyurethane spring Isolators
Factory 2013 JK Rubicon Moabs wrapped in the BFG MT KMs
-Thanks man.
post #14 of 17 Old 10-04-2013, 03:21 PM
Bear304inc
Are the charger wheels 5x4.5?
post #15 of 17 Old 10-04-2013, 03:27 PM
Bear304inc
-Thanks man.
CareyK did you need new control arms etc. For the HD springs?
