I thought my 249 VC was bad... - JeepForum.com
post #1 of 5 Old 10-18-2013, 02:43 AM Thread Starter
zjilla
So when i first bought the jeep (98 GC 4.0 w/ 249 TC) it binded bad when making sharp turns. the tires would hop and pop. I knew in time i would have to replace the VC or the TCase with a different model. The Jeep was lifted around 3.5-4" still on stock control arms. dont look at me...I bought it that way for a cheap price with plans on making the control arms right again.
I added WJ lower control arms which moved the axle forward about 1/2".
And guess what, the binding stopped.
Do you think the Tcase was having a problem taking turns bc the axles were too close to the center of the vehicle? Like i said i was on stock control arms.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #2 of 5 Old 10-18-2013, 05:54 AM
Technohead
Maybe the binding was the tires rubbing on something?
I can't see any possibility that pushing the axle forward would affect the t-case.
-Eric
Technohead is offline
post #3 of 5 Old 10-18-2013, 07:04 AM
PolkaPower
Or the bushings are brand new and it feels much better. If the VC is bad you just gave it new bushings to ruin.
PolkaPower is online now
post #4 of 5 Old 10-18-2013, 09:20 AM
ZJMatt
You may have helped the pinion angle some too, causing the drive shaft u joints to stop binding.
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #5 of 5 Old 10-18-2013, 04:44 PM Thread Starter
zjilla
I know its double cardain at the tcase...but even with a cv at the pinion?....if the vc was bad...with new or old CA bushings it woulf bind. These bushings are out of a junk yard and have miles regardless
Sent from my GT-N7000 using JeepForum
zjilla is offline
