I think the shop trashed my idler pulley - JeepForum.com
post #1 of 16 Old 12-13-2013, 07:29 PM Thread Starter
Gearhead31
Out of nowhere, I'm hearing this horrid sound from the engine area.. Sounds like it might be my upper idler, though it's not a sound I've heard from a pulley before, almost like the rattling/vibrating/pulsing sound from someone touching a subwoofer cone while it's pumping bass.. doesn't change with rpm's(same from 800-4,500 rpm) and disappears after 1 minute(almost like clockwork both times), only did it a couple times, once warm engine, once cold. I'm used to the grinding, metal on metal and squealing/squeaking from pulleys and being either continuous or sporadic and brief. I'm hoping it's just that and not my still fairly new alternator or the a/c compressor.
Of course there's been a couple gallons worth of coolant spilled over that whole area from previous thermostat gasket failures so I'm hoping it's that making it pulse(?). Either that or the shop overtightened the belt and trashed it...
*rant time* Why does karma have it out for me lately? A mysterious knocking out of knowhere that doesn't seem to fit any one problem, a possible dying pulley, insanely sporadic and erratic shifting starting in the middle of rush hr freeway traffic, and being sick for holiday parties.. Happy friday the 13th, I guess
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #2 of 16 Old 12-14-2013, 08:08 AM
motordoctor
That sounds like the power steering pump blowing up. At least that's the noise mine made right before it locked solid.....
motordoctor is offline
post #3 of 16 Old 12-14-2013, 08:18 AM Thread Starter
Gearhead31
Its definitely coming from the left half, which leaves the idler, ac and alternator.
post #4 of 16 Old 12-14-2013, 08:50 AM
PolkaPower
You need to get a long dowel rod or screwdriver and listen for where the sound is the loudest. Should take five minutes to find .
PolkaPower is online now
post #5 of 16 Old 12-14-2013, 08:54 AM Thread Starter
Gearhead31
Easier said then done with the fan spinning ;p its not doing it again now so when it crops up again, im planning on it to make sure
post #6 of 16 Old 12-14-2013, 02:15 PM
Oldfrog
2007 WK
That pulley near the air unit is $24 or less. Just buy one and keep it as a spare if that isnt the issue. You'll need it eventually.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 16 Old 12-14-2013, 04:04 PM
zjosh93
I just replaced both of my pulleys on my 93 for $7 each on Rockauto. If $7 is too much most auto parts places have just the bearing for a couple bucks less.
zjosh93 is offline
post #8 of 16 Old 12-15-2013, 08:38 AM Thread Starter
Gearhead31
For the bearing replacement, you need to separate the pulley from the bearings with a press, correct? If so, i'd rather just spend the money and get the whole thing replaced.
post #9 of 16 Old 12-15-2013, 08:41 AM
zjosh93
The amount of interference fit between the bearing and pulley is pretty moderate. You can replace them with a vice or a big C-clamp. The thin sheet metal of the pulley can't really support much crush anyway.
zjosh93 is offline
post #10 of 16 Old 12-15-2013, 09:00 AM Thread Starter
Gearhead31
Noted, thank you! I'll look around here, see how prices run. Probably going to replace the whole thing and use that as an emergency spare or something
post #11 of 16 Old 12-25-2013, 08:36 PM Thread Starter
Gearhead31
picked up a mechanic's stethascope and am still waiting for it to come back so I can zero in exactly which bugger was giving me grief. I sprayed a little bit of WD40 on that idler and it's yet to come back. I think it might have just been that, probably from having a huge amount of coolant purged onto it, both with engine off/cold and hot/running. I'll go ahead and pick up another pully soon because it will eventually go. I might as well have that on hand for the long trips to come!
post #12 of 16 Old 12-25-2013, 08:50 PM
zjosh93
Checked it out and the correct bearing should be a 6203-2rs which is a very common automotive bearing. The front bearing in our power steering pumps is the same and a lot of alternators use that bearing. There are some on Amazon for about $2 but you might find them locally. I pressed out the two in my pair of bad pulleys using my bench vise and a socket pretty easily.
zjosh93 is offline
post #13 of 16 Old 12-25-2013, 10:46 PM Thread Starter
Gearhead31
Thank ya. I'm probably just going to get a full idler pulley instead of just the bearing, be sure that all of it is good. Sure I could save some money but I figure it is money well invested in this case
post #14 of 16 Old 12-26-2013, 03:47 PM
zjosh93
Yeah I figured, I just wanted to close my advice in case someone else finds this thread in the future.
zjosh93 is offline
post #15 of 16 Old 12-26-2013, 04:09 PM Thread Starter
Gearhead31
Gotcha
