i think my transfer case is stuck - JeepForum.com
post #1 of 7 Old 10-13-2006, 07:16 PM Thread Starter
S10Eater
S10Eater's Avatar
ok the jeep 01 wj selec trac was in full time because we got some snow and the wifey was driving it. today the snow has melted and she was still driving in fulltime cause it was wet out (melting snow) and now that the streets are dry i put the tc into 2wd and i am still getting wheel scrub when i turn! whats up?
it feels like it got stuck in parttime or something
please help me!
1987 350 JEEP COMANCHE
Licence plate: FSTJEEP
2001 TJ SE, 31" KM2s, cragar d styles
JEEP: If i wanted a Hummer, I would have asked your sister
S10Eater is offline
post #2 of 7 Old 10-13-2006, 08:52 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Mine occasionally took a mile to unlock, but usually if I was rolling with the tranny in neutral when I put it in 2wd, it worked great. I did have to back up about 200 ft and throw the wheel to full lock while doing so once or twice, but it worked great all the time after that.
Other option, leave it in fulltime till spring. Won't hurt anything, gas mileage should be the same, and you'll have better grip.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 7 Old 10-13-2006, 09:39 PM Thread Starter
S10Eater
S10Eater's Avatar
so back up and crank the steering wheel to lock and that should do it?
S10Eater is offline
post #4 of 7 Old 10-13-2006, 11:10 PM
-Joe-
-Joe-'s Avatar
All your tires the same size?
Mabye the linkage shifted and your still in 4wd.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 7 Old 10-14-2006, 06:41 AM
BostonBull
I have had to back up a long ways and sometimes do the backing up in circles or pulling forward a fewtimes to get my old t-case out of 4 wheel
Wicked Pissah
81
BostonBull is offline
post #6 of 7 Old 10-14-2006, 11:15 AM
Woody
Woody's Avatar
1985
Check your linkage and fluid as well.
Mine shifted better with a new batch of ATF in the case.
Woody
Woody is offline
post #7 of 7 Old 10-14-2006, 12:41 PM
legend6009
legend6009's Avatar
so did mine!
-Andy-
06-tj-2.4 4 cyl, 6 speed. red, 2.25 bb on 31s, rear aussie locker, hella 500 series on bumper, mile marker pe8000, rock krawler rear bumper w/ hitch, optilux lights mounted on stainless steel windshield light brackets, in cab winch switch
red jeep club member 479
my myspace^
legend6009 is offline
Help Stuck Transfer Case!!!! 1997zj ZJ Grand Cherokee Forum 10 07-10-2011 04:55 PM
transfer case stuck in 4wd? lateralus3 ZJ Grand Cherokee Forum 3 07-18-2009 09:07 PM
Transfer case lever stuck fzillman ZJ Grand Cherokee Forum 14 08-15-2007 07:09 AM
stuck t-case bolts. Derek33 ZJ Grand Cherokee Forum 7 07-24-2007 01:06 PM
'93 ZJ stuck t-case shifter Crispin ZJ Grand Cherokee Forum 7 01-04-2007 02:32 PM
