I think my distributor is worn out - JeepForum.com
post #1 of 24 Old 07-04-2011, 06:36 PM Thread Starter
ZeeJay1997
When I grab the shaft and rotate, it has about 1* slop. When I wiggle the top of the shaft, it moves about 1/8".
Replace? What say you?
edit: Everything else has been replace at some time or the other...
ZeeJay1997 is offline
post #2 of 24 Old 07-04-2011, 06:55 PM
zander21510
Probably wouldnt hurt...notice any performance drops?
zander21510 is offline
post #3 of 24 Old 07-04-2011, 07:07 PM Thread Starter
ZeeJay1997
It misses from time to time. No codes lately. It happens more when the PCM would be adjusting the timing slightly, like changing from a slight grade to flat ground or vice versa. I can make it do it by feathering the pedal. That line of thought is what made me check it.
post #4 of 24 Old 07-04-2011, 07:19 PM
Virmagicus
Virmagicus's Avatar
Doesn't sound bad to me. A little play is normal for the age.
Jeff
Virmagicus is offline
post #5 of 24 Old 07-04-2011, 08:39 PM
zander21510
If I were you, I would try it and see if it fixed the problem, if not, you've eliminated one possibility Check your spark plugs and wires too if its missing. Maybe check timing belt too.
post #6 of 24 Old 07-04-2011, 09:24 PM Thread Starter
ZeeJay1997
It has a chain, not a belt, but i get your drift.
FSM says no more than 1/2" slack, but if I get that far, I'm replacing it...
Has anyone ever had a chain make one skip??
post #7 of 24 Old 07-04-2011, 10:08 PM
zander21510
lol well i couldnt remember if it was a chain or belt....i loose :P
I suppose a chain can't slip so theres that logic gone lol....maybe its something with the computer.
post #8 of 24 Old 07-05-2011, 04:40 AM Thread Starter
ZeeJay1997
I have a box full of those
post #9 of 24 Old 07-05-2011, 05:40 AM
melk
Rebuilt distrib is like $50 after core :shrug:
melk is offline
post #10 of 24 Old 07-06-2011, 04:21 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Zee, I;m not getting the 1" slop part. Mine started squealing like a pig on startup about 8 months ago and it turned out to be the bushings. The jeep was still running OK. Side to side play then was about 1/8. Replaced the dist. and all was groovy. Seems like I read somewhere that cardone is now offering "new" distributors. The last time I checked the dealer one was close to 400.
coralman is offline
post #11 of 24 Old 07-06-2011, 11:12 AM
ejschultz
ejschultz's Avatar
Hmm... got me thinking... (rarity). My ZJ does that at one certain stoplight in my area. There's a really steep downgrade leading up to the stoplight. If I'm on the downgrade and I have to stop for the light, by the end of the light, the ZJ is running like garbage. It doesn't do it every time, but when it does, it's bad. Could that be my distributor? I don't get any codes when it does it and it normally idles a little rough.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Xenon flat flares, Trail Gear front bumper, Tuff Stuff rear bumper, RH4X4 sliders, 33" STT Pros on 15x8s
ejschultz is offline
post #12 of 24 Old 07-06-2011, 05:57 PM Thread Starter
ZeeJay1997
That's one degree rotation, not 1 inch. It makes me think that any given time, the timing could off by up to 1 degree
post #13 of 24 Old 07-06-2011, 06:01 PM Thread Starter
ZeeJay1997
Doesn't sound a lot like a distro... unless you've eliminated a host of other possibilities. I can't say for sure because you're driving a V8 and I'm a 6 banger type.
post #14 of 24 Old 07-06-2011, 06:03 PM Thread Starter
ZeeJay1997
The money pit is hungry.
post #15 of 24 Old 07-06-2011, 07:01 PM
ejschultz
ejschultz's Avatar
I've essentially eliminated nothing. I'm going to swap my plugs. The wires and cap are newer (within a year and a half/20,000 miles). I recently did the "zip tie" fix for the connectors on my ECM and that actually seems to have made a slight difference. I wonder if the connections were coming loose and now they're tight. It's probably the placebo affect... Who knows. I also pulled my transmission and fuel pump relays and cleaned the connectors. I figured it wouldn't hurt while I was in there.
Replacing a worn out steering box 1995jeepgcrah ZJ Grand Cherokee Forum 5 03-05-2011 03:31 PM
Worn tie rod ZJPunk98 ZJ Grand Cherokee Forum 14 01-02-2011 08:53 AM
Inner Tie rod ends worn. Eckhard WK Grand Cherokee & XK Commander Forum 7 07-06-2008 06:07 PM
worn hood shocks... TheDon427 ZJ Grand Cherokee Forum 11 10-20-2005 11:13 AM
4.0L worn out......... Rebuild kit? Dr. Righteous ZJ Grand Cherokee Forum 7 05-14-2005 11:44 AM
