I think my d35 is finally on its way out - JeepForum.com
post #1 of 24 Old 05-01-2013, 04:34 PM Thread Starter
Bigdjs123
So today me and my girlfriend were doing some erronds and on turn no matter how wide or tight, it feels like the rear end is binding very badly. To the point that the steering wheel comes back to straight in incriments if that makes sense. It has been making the noise for awhile and up until yesterday it wasn't to bad. Now its every turn and very loud. I do have the trac lock. I think I read somewhere that if the clutches go bad it will do that. Is it true? Is it time to upgrade?
Bigdjs123 is offline
post #2 of 24 Old 05-01-2013, 06:49 PM
dnuccio
Whatever it is, I wouldn't spend money fixing a 35. Better off to swap in a stronger axle such as a d44a out of a 96-98 v8 ZJ or a ford 8.8
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 24 Old 05-01-2013, 07:10 PM
a70eliminator
Sounds more like a toasted viscous coupler rather than the rear dif. When LSD clutches wear out the dif just works like a conventional gear no binding should happen.
a70eliminator is offline
post #4 of 24 Old 05-01-2013, 07:51 PM Thread Starter
Bigdjs123
I have a 242 not a 249
post #5 of 24 Old 05-01-2013, 08:41 PM
dnuccio
maybe the clutches in the LSD have locked up and are working like a locker? thatd be my guess
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 24 Old 05-01-2013, 08:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You can try all the justification you want, those axles snap like twigs.
Luck Favours The Prepared
Anticanman is offline
post #7 of 24 Old 05-01-2013, 09:03 PM Thread Starter
Bigdjs123
That's what I'm thinking. I'm gonna call my dads mechanic tommarow and try and get him to look at it while I'm working becaise I don't have the time. If its the axle I'm just replacing it with a rebuilt 44a
post #8 of 24 Old 05-01-2013, 10:42 PM
dnuccio
thats my plan as well. i kind of beat the **** out of my 35 hoping it will break so i have an excuse to tell my dad i need to put a 44a in it
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 24 Old 05-01-2013, 11:04 PM
RIPNBST
Why use the 44a? I'd rather go 8.8 or 44HD. If you're gonna do it, do it right.
RIPNBST is offline
post #10 of 24 Old 05-02-2013, 03:35 AM Thread Starter
Bigdjs123
I don't have access to a welder and there are no shops around me that do that kind of fabrication otherwise I'd already have an 8.8 in there
post #11 of 24 Old 05-02-2013, 06:20 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
44a is the 44hd.
Can't say I've ever heard of a clutch based lsd failing to locked.
If the fluid is very neglected they'll chatter and lock though.
ratmonkey is offline
post #12 of 24 Old 05-02-2013, 08:22 AM
dnuccio
44a is a direct bolt in except for some driveshaft mods. great upgrade for guys that dont plan to upgrade it much further.
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 24 Old 05-02-2013, 09:32 AM Thread Starter
Bigdjs123
What will I have to do with the driveshaft? Shorten it?
post #14 of 24 Old 05-02-2013, 09:35 AM
PolkaPower
The D44a is like an inch longer at the pinion I think. So yea shorten it.
PolkaPower is offline
post #15 of 24 Old 05-02-2013, 10:09 AM Thread Starter
Bigdjs123
Would a transmission shop be able to do somethin like that?
