I think im missing the wiring to my Crankshaft Position (CKP) Sensor! - JeepForum.com
post #1 of 12 Old 09-14-2009, 01:19 PM Thread Starter
littlefdl
1994 ZJ
I have been wondering exactly what this clip connects to that sits directly behind the oil filter. I have found out that it connects to the Crankshaft Position (CKP) Sensor but i can't find the wiring coming from it. I have searched just about everywhere for it and haven't found it yet. My question to you is will my Jeep even drive minus the CKP??? It drives great, no sputtering at all. Im baffled
littlefdl is offline
post #2 of 12 Old 09-14-2009, 01:24 PM
rugermack
If the wiring/plug for the CPS in not plugged in, it won't run at all.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #3 of 12 Old 09-14-2009, 01:29 PM Thread Starter
littlefdl
1994 ZJ
I heard some GC's were equipped with a Oil Level Sensor??? Is the wiring for this by the pan somewhere?
post #4 of 12 Old 09-14-2009, 01:45 PM
WiCkeDuDe
WiCkeDuDe's Avatar
I have no idea what you are trying to say. The CKP is back near the bell housing and its plugged in or your Jeep would not start. Are you saying the connection you have in your hand is for the CKP? You cant find what wiring?
Ive read your post 5 times and I cant figure out what you are saying.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #5 of 12 Old 09-14-2009, 01:48 PM Thread Starter
littlefdl
1994 ZJ
Im trying to to figure out what this connector goes to. If the Jeep won't run without the CKP being plugged in, thats out of the picture. Maybe it goes to the Oil Level Sensor, Im askin where it's located
post #6 of 12 Old 09-14-2009, 01:58 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Do all your gauges work??
The only thing I know in that area are the oil pressure sender and the coolant temp sensor.
post #7 of 12 Old 09-14-2009, 02:44 PM
StellaTheZJ
This is definitely the plug for the oil LEVEL sensor, which were not installed on very many Jeeps, or at least I've never seen one! But the wiring is there on the 93-95 ZJs.
StellaTheZJ is offline
post #8 of 12 Old 09-14-2009, 06:49 PM
impuresoul2k3
My 93 ZJ has the oil level sensor
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #9 of 12 Old 09-14-2009, 08:06 PM
rooster51
3rd confirmation, just so your clear.
Terry
rooster51 is offline
post #10 of 12 Old 09-15-2009, 04:05 PM
StellaTheZJ
impuresoul2k3, I love the idea of the Oil Level Sensor. For me, having a GC is all about those extra little touches. My 96 has no provision for one, or I'd be checking the wrecker for them (along with all the other planned upgrades).
Does it work OK? Does it "warn you" if you're on a serious angle?
post #11 of 12 Old 09-15-2009, 09:20 PM
impuresoul2k3
It usually only throws a false reading on an incline if the oil level starts getting a little low. If its full I never have a problem with it.
Air hat spacer
Flowmaster muffler
post #12 of 12 Old 09-16-2009, 03:50 AM
BigE3
oil level is the side of the pan and the wiring in loomed into the starter wires. that looks like the oil pressure sender near the distributor
I like my Jeep, just like my women. 'Loose and Flexible'
BigE3 is offline
Crankshaft Position Sensor 02jeepgrand ZJ Grand Cherokee Forum 30 04-15-2013 05:43 AM
Is my Crankshaft Position SEnsor going in my 04 GC?? sammysue04 ZJ Grand Cherokee Forum 2 12-24-2008 07:34 AM
crankshaft position sensor? petey156 ZJ Grand Cherokee Forum 4 02-16-2007 08:56 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
Crankshaft Position Sensor(CPS) 97zjjeeper ZJ Grand Cherokee Forum 15 02-05-2006 12:20 PM
