I smell oil - JeepForum.com
post #1 of 10 Old 04-09-2008, 09:41 AM Thread Starter
cweb
2005 WK
I smell oil
after a drive i smell burnt oil. i notice a few drips on the garage floor but nothing life threating, it's not a pool, just a few drips overnight. I suppose an oil leak could come from a million different places. Just thought I'd mention it, see if anyone had any thoughts. I just changed to the high mileage Quaker State to hopefully seal up any age related holes or cracks.
2005 Jeep Grand Cherokee Laredo
4.7L V8
cweb is offline
post #2 of 10 Old 04-09-2008, 09:50 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
obviously look all over the engine for fresh oil, and use a dye and a blacklight if needed, but i would look more further up on the engine, sounds like the oil is dripping down the engine, where it is burned.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 10 Old 04-09-2008, 10:28 AM
JeepOrvis97
JeepOrvis97's Avatar
The oil is probably leaking from the valve cover gasket and burning on your exhaust manifold. My Lumina does that, it wasn't bad but now its leaving a huge puddle of oil in the driveway so, it time to fix it, unfortunately its the back gasket which will be very fun to get to.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #4 of 10 Old 04-09-2008, 10:30 AM
driabyor
driabyor's Avatar
1994 ZJ
could be the oil spilled on the exhaust when you changed the oil.. well if it spills on your exhaust
valve cover....
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 10 Old 04-09-2008, 11:12 AM Thread Starter
cweb
2005 WK
valve cover....
Yea, I thought that too, but even if I don't spill any or weeks after the oil change it's still doing it I figure it's something else.
4.7L V8
cweb is offline
post #6 of 10 Old 04-09-2008, 11:39 AM
JeepOrvis97
^^^^^Did you read my post????^^^^^ Valve cover gasket.
Current jeeps:
1997 ZJ Orvis
post #7 of 10 Old 04-09-2008, 11:50 AM
FlipFlop425
get some dye and put it in and use a light to find the leak or clean the engine with engine bright and look to see where you see fresh oil.
FlipFlop425 is offline
post #8 of 10 Old 04-19-2008, 07:46 PM Thread Starter
cweb
2005 WK
Where might this "Valve cover gasket" be located? Also, dye has been mentioned, you suggesting I put a dye into my oil to see where the leak might be coming from?
4.7L V8
cweb is offline
post #9 of 10 Old 04-19-2008, 09:25 PM
UUJ1
The valve cover gasket is in between the valve cover and the head.
and the dye... yes, that's how you expose a hard to find leak...
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #10 of 10 Old 04-19-2008, 09:39 PM
elmer_fud
x2, The first thing i would do is tighen all the bolts on the valve cover. If that doesn't work, look for oil on the enigine and trace it back to the source.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
Really odd smell KABADB WK Grand Cherokee & XK Commander Forum 14 09-21-2009 12:22 PM
A/C Smell Larrysjgc ZJ Grand Cherokee Forum 0 04-28-2009 04:20 AM
Gas Smell!! JeepRagan ZJ Grand Cherokee Forum 6 10-03-2007 05:29 PM
Oil Smell wlmuncy ZJ Grand Cherokee Forum 8 12-19-2005 04:18 PM
Bad Smell wreck76 ZJ Grand Cherokee Forum 6 11-26-2004 04:37 PM
