I need your opinions on a Trans question - JeepForum.com
post #1 of 2 Old 01-06-2003, 04:15 PM Thread Starter
sam270
Greetings - My trans has been slipping between 2nd and 3rd (1994 GC, 6 Cyl, Auto 4x4). My mechanic ran some tests and reports that his equipment tells him the band between 2nd and 3rd has a wide gap that needs to be tightened. He warns this may or may not correct the problem. This will cost $150. Should I gamble and pay the 150 or bite the bullet and go for the rebuild?
Thanks. Sam
BTW - What's a good price for a rebuild. I'm hearing anything from 1100 to 2400.
sam270 is offline
post #2 of 2 Old 01-06-2003, 08:16 PM
ZR7 Ken
ZR7 Ken's Avatar
I doubt that you have a band problem. The change that takes place from 2nd to 3rd is the engagement of the forward clutch pack. Actually, this is a somewhat common problem with "RE" transmissions. The piston seals wear out at an accelerated rate and cause an RPM flareup from 2nd to 3rd, or no 3rd gear at all. There is an updated forward clutch assembly (from Mopar) available that uses a different style piston and drum.
As this requires removal of the transmission, I'd at least check the other clutch packs and replace the seals while I was in there. Flushing the trans cooler is strongly recommended.
I have no idea about prices. I just work on them; the service writers deal with the money
I'm just putting in my opinion; as I have not actually driven or worked on your Jeep, I couldn't be absolutely sure that the forward clutch is the problem.
Hope I helped
Ken
ZR7 Ken is offline
WJ trans flush opinions needed 2tone93zj ZJ Grand Cherokee Forum 0 11-19-2009 09:46 AM
Opinions on the best WJ engine/trans/T-case combo KN94ZJ ZJ Grand Cherokee Forum 14 04-30-2009 04:26 PM
New problem I think its the trans mount..opinions needed! platinum5.9 ZJ Grand Cherokee Forum 3 07-21-2008 01:54 AM
WJ Trans question jeepmann45 ZJ Grand Cherokee Forum 7 01-31-2008 11:07 AM
trans question biggator64 ZJ Grand Cherokee Forum 1 03-02-2006 07:07 AM
