I need some advice - Page 2 - JeepForum.com
 1Likes
post #16 of 25 Old 10-25-2016, 09:00 AM
PolkaPower
Originally Posted by Timo_90xj View Post
You mean strength issue? Yeap, the uppers will bend if you pull them from the Jeep and twist with your bare hands. But lowers get to see rock rash, and they don't handle that well at all
When I pulled all eight CAs from my jeep after wheeling it on fairly easy trails for a few months, I had 7 out of 8 bent. Only one rear UCA had survived more or less in good condition.
Stock lower mounts are flimsy too. They will fold or rip off in a light breeze.
Good idea to weld skids onto them if not replace entirely.
PolkaPower is online now
post #17 of 25 Old 10-25-2016, 11:08 AM
PCsZJ
Message a member named kolak. Good stuff and good prices.
I like IRO 3.5 lift with 31's.
PCsZJ is offline
post #18 of 25 Old 10-25-2016, 11:22 AM
PolkaPower
Whats the point in 3.5" for 31's when you can fit them with 2" and keep a lower cog?
post #19 of 25 Old 10-25-2016, 12:10 PM
tjcustomranger
I drag my lowers through whatever cause honestly i don't give a **** about the control arms and they are beat to hell and tweaked with all kinda of scrapes but they arent broken or effecting drivability.
I broke 2 sets of uppers then built some and ****ed my upper mounts
tjcustomranger is offline
post #20 of 25 Old 10-25-2016, 12:11 PM
tjcustomranger
My lower mounts are slightly tweaked inwards on themselves haha. I have to put new ones on
post #21 of 25 Old 10-25-2016, 12:12 PM
tjcustomranger
In my area a bb doesn't do **** for you so i had to go to 3.5 and it gave just enough extra travel to,get through the trails without skinny pedal.
But i went to 32x11.5 not 31s.
I will soon be on 35s, 3.5 and front long arms
post #22 of 25 Old 10-25-2016, 02:23 PM
PCsZJ
That is what I like.
PCsZJ is offline
post #23 of 25 Old 10-25-2016, 02:32 PM
PolkaPower
Well that's wrong. Haha just kidding.
post #24 of 25 Old 10-25-2016, 02:50 PM
Timo_90xj
Timo_90xj's Avatar
My LCAs were twisted enough (other was S- shaped, other was.. well.. bent) for the axle to be slightly diagonally under the Jeep. The front LCAs also started to rip apart. In addition to that, they are just crap as is..
As for the CA mounts, so far I've halfway ripped off both my OEM front LCA frameside mounts (replaced with DIY stronger ones + frame plating on that area), both front UCA frameside mounts were partially cracked off from the uniframe (re-welded and strengthened), one front axle LCA bracket on the original LPD30 bent slightly. About a month ago I noticed my drivers' rear UCA frame mount is almost fully cracked off from the uniframe.
These damn grocery- getters don't like wheeling..
***Under construction***
Timo_90xj is offline
post #25 of 25 Old 10-25-2016, 02:59 PM
tjcustomranger
The stock lowers are junk but they typically outlast the uppers.
My rear ones are fine, I'm done with short arms in the front so the mounts can suck a dick
