I need help fast! - JeepForum.com
post #1 of 14 Old 05-09-2013, 05:02 PM Thread Starter
Jramos43
I need help fast!
My truck is acting weird, or maybe its normal... which i doubt, I'm going to include here a link to the YouTube video of what it does. Please watch it and see if you can figure out what it is! Thanks
96 ZJ
Jramos43 is offline
post #2 of 14 Old 05-09-2013, 05:19 PM Thread Starter
Jramos43
Jramos43 is offline
post #3 of 14 Old 05-09-2013, 05:24 PM
homerx
Hate to say this pal but ur transmission is not shifting out of drive.
homerx is offline
post #4 of 14 Old 05-09-2013, 05:34 PM Thread Starter
Jramos43
Well the truck drives, it moves, shifts... Only thing that doesn't seem to be working is the full time 4x4 which i had explained in my previous threads.
96 ZJ
Jramos43 is offline
post #5 of 14 Old 05-09-2013, 07:41 PM
DickDickle
If his transmission was stuck in drive why would the wheels be going backwards......that grinding sound when the wheels start spinning and right before they stop does not sound good at all, you may have a t-case problem, which one do you have?
DickDickle is offline
post #6 of 14 Old 05-09-2013, 07:45 PM
jnicewan
What are you wondering, I see two problems or possibly two problems. 1. Tires powered in reverse with shifter in park. 2. Only saw one front tire but maybe the front end is not engaged?
jnicewan is offline
post #7 of 14 Old 05-09-2013, 07:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
from your other thread, it's probably not the tcase that's the problem with the front, it's most likely something broken in the front axle.
some verbiage on the problem you're experiencing now, instead of "here's a video i just made" would go a long way to troubleshooting.
it appears to be in reverse while in park and also still tripping the neutral safety switch. it should not be able to start in that situation.
do you have park? does it roll when you leave it on an incline?
there's a serious lack of information here.
ratmonkey is offline
post #8 of 14 Old 05-09-2013, 09:18 PM Thread Starter
Jramos43
Sometimes the park doesn't go in all the way, so while it may appear that it is on park the truck will roll back and something will click. but all i have to do is just put in the park good and it won't roll anymore.
I have the 249 TC
96 ZJ
Jramos43 is offline
post #9 of 14 Old 05-09-2013, 09:30 PM
KoreaZJ
1994 ZJ
Make sure your shift cable is properly adjusted.
KoreaZJ is offline
post #10 of 14 Old 05-09-2013, 09:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
park is not in the transfer case. the case will have nothing to do with that.
sounds like the linkage needs adjusted at the transmission. possibly a bent park rod, but reverse wouldn't likely still be engaged if it was that. remove the linkage at the trans. put it all the way in park with the lever on the trans. be sure the shifter is in park. then adjust the linkage till you can pop it back onto the lever without pulling on it.
post #11 of 14 Old 05-10-2013, 07:53 AM
Rich93ZJ
There was a recall on the park detent for the shifter. Don't remember if it covered the 96 model but its worth looking into. Get your build sheet from Jeep and it will list any and all recalls for your vehicle.
Rich93ZJ is offline
post #12 of 14 Old 05-10-2013, 12:03 PM
speedbucket
this....i had this as an open recall on my 93, they put a spring in so it fully goes into park. as far as the front not spinning (i haven't read other thread) the rear being off the ground may not create enough friction for lock up(space age fluid/clutches heating up) of the VC
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #13 of 14 Old 05-10-2013, 05:08 PM
tucsonzj
is on the 95 (still haven't gotten mine taken care of )
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #14 of 14 Old 05-11-2013, 06:21 AM
Rich93ZJ
Sorry Rat, Didn't mean to jump on your suggestion. OP, Please check what (ratmonkey) has suggested first. The recall is safety related and probably will not fix the issue but sounds related to you situation.
Rich93ZJ is offline
