i'm swapping a 5.2 to 5.9, anything else i should do while its taken apart? - JeepForum.com
post #1 of 4 Old 03-13-2010, 01:31 AM Thread Starter
snotrod
hey guys, i'm new to this forum, i tried searching but couldnt really find what i was looking for. i'm in the process of swapping a 5.9 into a 96 5.2, and i wanted to know if there was anything with these motors that usually dont get done that i should do while i have everything apart, anything at all that are buggers with these motors, anything that you can recommend. i dont really need help with the swap, i've done plenty before. just new to the chrysler/jeep motors and any quirks they might have.
thanks in advance!!
Stephan
snotrod is offline
post #2 of 4 Old 03-13-2010, 01:51 AM
JrMechanic
Timing set, plenum gasket (upgrade to a Hughes or APS plate, or make your own), oil pump, and rod bearings if you're in the mood.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 4 Old 03-13-2010, 02:49 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
oil pump, water pump, plenum plate.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #4 of 4 Old 03-13-2010, 04:03 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You won't find an easier time to pull the heads on the new motor and inspect the bores and valves. Cost you a set of head gaskets and precious time.
HighLonesome is offline
swapping my 5.2 v8 with a 5.9 v8 - please help!! SouthAfricaJeep ZJ Grand Cherokee Forum 119 10-13-2016 01:19 PM
Swapping in a 231 into a WJ GraKee99 ZJ Grand Cherokee Forum 3 04-15-2009 07:37 AM
Swapping D44a axles, anything funny about swapping their brakes? Jerry Bransford ZJ Grand Cherokee Forum 9 02-26-2009 08:40 AM
Swapping a 4.7HO into a non-HO WJ? AgitatedPancake ZJ Grand Cherokee Forum 1 02-02-2008 01:37 PM
Wj rim swapping B_palmer22 ZJ Grand Cherokee Forum 11 12-16-2007 09:02 PM
