I'm confused about towing capacity - JeepForum.com
 2Likes
post #1 of 32 Old 07-08-2017, 05:14 PM Thread Starter
sujane80
1998 Jeep Grand Cherokee Laredo. I had a transmission cooler and trailer brake controller put on recently. Getting ready to tow a 2000 lb fiberglass trailer. But I read that I need to take the GCWR into consideration, which is 5300. The Jeep itself weighs 3825 (curb weight). That only leaves 1475 left for the trailer. How can it be rated to tow 5000 lbs then??
Note: Edit: The figure of 5300 was the GVWR not the GCWR which I assume will be higher. I just can't seem to find out what that is anywhere. Anyone know a good source to find out what it is?
sujane80 is offline
post #2 of 32 Old 07-08-2017, 05:23 PM
vlackattack
Where are you getting that 5300 number from? This website: http://www.automobile-catalog.com/ma...1gen/1998.html shows a GVWR of 5300 for a 4.0 and 5500 for a 5.2. The GCWR should be well above that.
vlackattack is offline
post #3 of 32 Old 07-09-2017, 10:10 PM
Pugulis
You're making things too complicated. ZJ's equipped with a factory towing package were rated at 5000. That's the tow weight of the object being towed. They rated it lower, if you had an aftermarket hitch, because the gear ratio was different on jeeps with a tow package. And if you have a 5.9, it's rated higher, because of the higher HP. These are all general numbers. Personally, I wouldn't worry a bit about towing a 2000 lb trailer, unless you're loading more than 3000 lb of stuff in it.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #4 of 32 Old 07-09-2017, 10:19 PM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
Press the OD OFF dash switch when towing.
wingless is offline
post #5 of 32 Old 07-09-2017, 10:46 PM
kg6mov
Hears the voices
kg6mov's Avatar
The 5.9 is actually rated lower than a similarly equipped 5.2 because of the efan.
Any 98 should have an aux trans cooler added before being used as a tow vehicle as they did not have them from the factory.
kg6mov is offline
post #6 of 32 Old 07-09-2017, 11:37 PM
azzkicker
2007 WK
I think the OP already caught on, but GVWR is the gross vehicle weight rating, which is what sits on the two axles of the jeep, including tongue weight of any trailer.
GCWR is gross combined weight rating, and that is the vehicle, cargo, and trailer. When they give you a tow rating of "5,000 pounds", there's an asterisk or two with that. It assumes you have a certain amount of cargo, but not the limit.
In any case, you're fine at 2k. When you get to the limit, you need to start looking at each part, but well under the limit is no concern.
Just for fun, my motorhome chassis is rated at a GCWR of 18,500 pounds. The GVWR is 13,500. When I pull on the scales loaded for camping, I'm about 12,500. That leaves me with chassis towing capacity of 6,000 pounds. The stock hitch was only rated for 3,500 pounds, so in order to use the capacity I had to upgrade the hitch.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #7 of 32 Old 07-10-2017, 06:24 AM
Timo_90xj
Timo_90xj's Avatar
..and regarding the weights, the exact same ZJs are rated for lot heigher tow limits here across the ocean: 4.0/ 5.2 have a maximum tow limit of 3500kg, 5.9s at a slightly lower 3360kg.
Thse are roughly 7800lbs. and 7500lbs. in your figures. Any trailer above around 1600lbs requires trailer brakes by law here.
***Under construction***
Timo_90xj is offline
post #8 of 32 Old 07-10-2017, 07:06 AM
jeepjeepster
Always amazes me when you post that. Think I say this every time you post that but my 4.0 wouldnt be able to touch that here.
Not sure I would want to tow that much with my 5.9 even if it had a mechanical fan....
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #9 of 32 Old 07-10-2017, 08:02 AM
Timo_90xj
Timo_90xj's Avatar
I gotta agree that trying to tow 7800lbs. with a 4.0 would be just about miserable even on flat land But that's what they are rated for here. People usually stick with maximum of about 5k loads with the 4.0, but I've seen people tow heavier stuff with smaller engines.
One thing you gotta keep in mind is our speed limit if you're towing a trailer is 50mph (80km/h).
Dodge full size pick-ups had exactly the same powertrain on them as a 5.9 ZJ, and those 5.9 Magnum- powered trucks were rated for almost 10k tow limit and up to 15k lbs. GCWR
ZJ niner certainly has the oomph to pull 7500-7800lbs. - which it does pretty damn easily - and you're not gonna damage the tranny if you install a large enough tranny cooler. I've pulled 7k+ loads with my niner and you don't even necessarily need to disengage OD on flat land
post #10 of 32 Old 07-12-2017, 08:12 PM
8v-of-fury
My 4.0 on 31's and 3.55's struggles to get 2000lbs moving up a grade from a stand still.. I live in a very hilly area, and its horrible.
5000?! No friggin way!
'98 ZJ 4.0/242, Locked d30/d35, 31x10.5x15, 2" BB w/ Bilstein 5100's
8v-of-fury is offline
post #11 of 32 Old 07-12-2017, 08:18 PM
Pugulis
Did yours come stock with a tow package? My 96 did, and I could tow a 3500 lb camper with no problems at all. Plenty of power. But the tow package gives a better gear ratio.
Pugulis is offline
post #12 of 32 Old 07-12-2017, 08:27 PM
LouC
2007 WK
3.55s on 31" tires is a bad combo for towing; they are 2.5" taller than the OE tire size. It will tow 4500 ok on stock size tires because when I first bought our boat that's how I towed it. With 31" tires you would want at least 4:10s for towing...
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #13 of 32 Old 07-12-2017, 08:48 PM
8v-of-fury
No tow package, thus the 3.55's lolol. She needs some 4.56's! LOL
Honestly though, every "Truck" or "off roader" has a minimum of 31's round here. I highly doubt stock tires would really make it any better though, although the math is there.
Lets put it this way, my 1.9 tdi swapped 84 Jetta tows the same weight better than the Jeep... lol
post #14 of 32 Old 07-12-2017, 09:46 PM
PolkaPower
Tires make a huge difference. You had 3.55 gearing with stock tires but the larger tires effectively reduces that further. It's a struggle for the transmission.
PolkaPower is online now
post #15 of 32 Old 07-16-2017, 10:49 PM
AlamoJeeper
AlamoJeeper's Avatar
Look in your owner's manual for the towing equipment requirements (engine size, axle ratio, etc.) at different towed weights. The factory claims that '98 ZJ's had better transmission fluid coolers in the radiator so didn't need the transmission fluid cooler in front of the radiator. An auxiliary transmission fluid cooler is probably good insurance if you are going to be doing much towing. You can get a factory auxiliary transmission fluid cooler from 97 and earlier ZJ's from the junk yard.
You can check my signature for how to get a listing of your ZJ's equipment and options as it left the factory.
AlamoJeeper
- 1995 4.0L ZJ NP249 - mostly stock
For an equipment list, go to
. Under "YOUR VEHICLE", click "Equipment Listing". Then enter the VIN (all caps). Despite what they say, it will work at least to 1993.
AlamoJeeper is offline
